| php functions empty [message #99934] |
Fri, 17 July 2009 06:13  |
Al Kativo Messages: 1 Registered: July 2009 |
Junior Member |
i downloaded yersterday the eclipse-php-galileo-win32.zip and installed
it. Then I made istallation of site-1.6.2.1.zip for svn. I checked out a
project. Everything cool. But then I donŽt have any php functions. Not i
the view or even on strg+space. Also strg+mouseover donŽt tell me where my
functions are. I lost one day on trouble. I don`t find anything. Please
help me.
Cucu
Al
Re: php functions empty [message #480075 is a reply to message #99934] |
Thu, 13 August 2009 13:05   |
Simen Thorsrud Messages: 1 Registered: August 2009 |
Junior Member |
My PHP Functions view is empty too, which is a shame. I have tried reinstalling different versions of Eclipse and even manually installed the PHP-related packages in Eclipse's software update management system.
But still no PHP Functions view. Is anyone able to help?
By the way, I am using Mac OS X 10.5.7 on a MacBook Pro.
/ S
Edit: I'm using Eclipse for PHP Developers. Build id: 20090619-0625.
[Updated on: Thu, 13 August 2009 13:07] Report message to a moderator
| Re: php functions empty [message #483640 is a reply to message #483630] |
Wed, 02 September 2009 08:29  |
Burt Crepeault Messages: 3 Registered: July 2009 |
Junior Member |
Correction to my last:
Here is the complete list of steps to work around this problem:
1) From Eclipse, create a new PHP project, including a new PHP file within
it.
2) From a terminal, copy the .project file from the newly created project
to all checked-out projects. Manually edit the copied .project files to
reflect the proper project name (between the <name></name> tags).
3) Copy the .buildpath file from the newly created project to all
checked-out ones. Manually edit the copied .buildpath files to reflect
your environment (I don't use this personally so you'll have to figure it
out).
4) Copy the .settings/ folder from the newly created project to all
checked-out ones. In the folder is a file named
org.eclipse.php.core.prefs. Manually edit this file for all checked-out
projects to reflect the proper project include path (after the
include_path= make sure you have 0;<your include paths separated by
semi-colons> so it looks like this: include_path=0;<your path 1>;<your
path 2> )
5) Restart Eclipse.
Hope that helps. Hope also that someone would tell me a better way to do
this...
FUDForum. Page generated in 0.06413 seconds
