Home » Archived » EGL Development Tools » 0.8 M2 RUI Properties Library generated code error
0.8 M2 RUI Properties Library generated code error [message #814828] Tue, 06 March 2012 23:25 Go to next message
Dan Darnell is currently offline Dan DarnellFriend
0.8 M2 release...
With the following:
library Properties type RUIPropertiesLibrary {}
	upsAccessKey string;
	upsUserID string;
	upsPassword string;
end
The generated Java code has an error on the import:
import eglx.ui.rui.NLSLibrary;
The error is "The import eglx.ui.rui cannot be resolved".
Need a bug submission on this or did I screw something up?
--Dan
p.s. Do you want to know about things like this on milestone releases?
[Updated on: Tue, 06 March 2012 23:25]
Report message to a moderator
Re: 0.8 M2 RUI Properties Library generated code error [message #815102 is a reply to message #814828] Wed, 07 March 2012 08:27 Go to previous messageGo to next message
fahua jin is currently offline fahua jinFriend
Member
My understanding is that the RUIPropertiesLibrary is only supported in JS generation, so it reports the error.
Re: 0.8 M2 RUI Properties Library generated code error [message #815316 is a reply to message #815102] Wed, 07 March 2012 13:57 Go to previous messageGo to next message
Justin Spadea is currently offline Justin SpadeaFriend
Member
Yes, RUIPropertiesLibrary can only be generated to JavaScript. There isn't yet "generator-level validation" to handle when trying to generate a part to an invalid target language, so for now you have to be careful which generators are enabled for which parts otherwise generation could throw an error and/or produce code that won't compile/run.
-Justin
Re: 0.8 M2 RUI Properties Library generated code error [message #815435 is a reply to message #815316] Wed, 07 March 2012 16:55 Go to previous message
Oh, right. Duh. I put the RUI properties library into the "common" package. I should have put it in the "client".
You know though, while we are on the topic, I recall that even in RBD I've been jumping through hoops to be able to have the same properties available in Java that I have in JavaScript via the RUIPropertiesLibrary. In the JSF world I used getMessage() to access externalized properties and while this is still available on the Java side of a RUI app it takes extra configuration (and a copy of the properties file in a different location) to make it work.
I am wondering if anyone else thinks it would be helpful to rethink properties in terms of a "PropertiesLibrary" type that can be generated to both JS and Java?
--Dan
Previous Topic:Snippets!
Next Topic:"x is not a constructor" error using XML record definitions
Current Time: Tue Feb 20 00:27:24 GMT 2018
Powered by FUDForum. Page generated in 0.01519 seconds
