Home » Eclipse Projects » Eclipse Platform » Eclipse crashes after SVN commit
Eclipse crashes after SVN commit [message #814686] Tue, 06 March 2012 19:20 Go to next message
Daniel Stammler is currently offline Daniel StammlerFriend
i'm trying to connect a project with a svn repositorie. Unfortunately eclipse crashes after clicking on "Commit" without a message. I looked at the log file and found this message:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x0cb6a0c1, pid=5786, tid=251874160
# JRE version: 7.0_03-b04
# Java VM: Java HotSpot(TM) Client VM (22.1-b02 mixed mode linux-x86 )
# Problematic frame:
# C [libsqlite3.so+0x60c1] sqlite3_free+0x101
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# If you would like to submit a bug report, please visit:
# _ttp://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
I'm using Version: Indigo Service Release 2
Build id: 20120216-1857
svn: Subclipse 1.8.5
Subversion JavaHL Native Library Adapter 1.7.3
It would be very nice if you could help me.
Kind regards,
Daniel
Re: Eclipse crashes after SVN commit [message #816201 is a reply to message #814686] Thu, 08 March 2012 14:42 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
Hi Daniel,
Just a guess, can you try setting the
-Dorg.eclipse.swt.browser.DefaultType=mozilla java property as described
in http://www.eclipse.org/swt/faq.php#browserspecifydefault ? I'm
guessing that the SVN plug-in is creating a Mozilla-style Browser, whose
shipped sqlite3 lib is conflicting with the one on the OS that is
referenced by WebKit-based Browsers.
Grant
On 3/6/2012 2:20 PM, Daniel Stammler wrote:
> Hello,
> Kind regards,
> Daniel
Re: Eclipse crashes after SVN commit [message #816273 is a reply to message #816201] Thu, 08 March 2012 16:24 Go to previous message
It worked, thank you very much!
Previous Topic:Indigo and Maven (m2e) Integration suddenly stopped working
Next Topic:Open Resource dialog : how to restrict extension to js ?
Current Time: Sat May 26 08:25:38 GMT 2018
Powered by FUDForum. Page generated in 0.01491 seconds
