Home » Eclipse Projects » Eclipse Process Manager (Stardust) » Model loading fails with exception(Model loading fails with org.eclipse.ui.PartInitException)
Model loading fails with exception [message #813569] Mon, 05 March 2012 07:50 Go to next message
Ghanshyam Baheti is currently offline Ghanshyam Baheti
I am trying to open model but model loading fails with below exception. Please Help.
org.eclipse.ui.PartInitException: Error loading the network.
at ag.carnot.workflow.model.diagram.editors.WorkflowModelEditor.updateModel(WorkflowModelEditor.java:933)
at ag.carnot.workflow.model.diagram.editors.WorkflowModelEditor.init(WorkflowModelEditor.java:767)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:799)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:643)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:428)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:306)
Re: Model loading fails with exception [message #813572 is a reply to message #813569] Mon, 05 March 2012 07:57 Go to previous message
This issue comes when model is created in earlier stardust version and trying to load it in latest version.
Check the stardust version in which model is created and open in the same, issue should get resolved.
[Updated on: Mon, 05 March 2012 07:58]
Report message to a moderator
Previous Topic:The audit trail contains no model Exception/Message
Next Topic:Character encoding/decoding to UTF-8
Current Time: Wed May 22 19:59:55 EDT 2013
Powered by FUDForum. Page generated in 0.01464 seconds
