Home » Newcomers » Newcomers » Problem with changing perspectives
Problem with changing perspectives [message #813561] Mon, 05 March 2012 12:36 Go to next message
R Ok is currently offline R OkFriend
Hello.
I hope it's the right place to ask.
I have a problem with switching from c++ perspective to java. I'm able to see the all the projects (java and C++) in Project Explorer only when the C++ perspective is chosen. Switching to java causes the Project explorer to disappear and package explorer to appear. I can make a new java project by clicking in white space, however the project is visible only in project explorer and I have to switch to C++ persp. to see the new project. The weirdest thing - name of project of C++ project I made a long time ago appears at the top of the eclipse window: proj name - Java - Eclipse SDK.
And when I switch to java persp. I see that proj. name too in Package Explorer tab.
Could someone, give an advice how to fix this issue,please?
Thank you in advance.
Roman.
Re: Problem with changing perspectives [message #813609 is a reply to message #813561] Mon, 05 March 2012 13:49 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
On 2012.03.05 5:36, R Ok wrote:
> Hello.
> Java - Eclipse SDK.
> Explorer tab. Could someone, give an advice how to fix this
> issue,please? Thank you in advance. Roman.
There shouldn't be a problem here, but if it's not particularly
important to you to see both types in the same workspace, you could
consider separate workspaces for Java and for C/C++. It's also possible
to maintain separate Eclipse installations for the two.
I'm not advising you to do this at all, I'm just saying that if your C++
and Java worlds don't overlap, separating them will certainly solve your
problem.
Also, don't overlook the Eclipse CDT forum where folk who use Eclipse
for C/C++ hang out to answer questions.
Previous Topic:Disable / Remove Rename Functionality from Eclipse IDE & Target Platform
Next Topic:Using Eclipse w/ Jazz plugin to checkout code
Current Time: Fri Apr 20 05:22:50 GMT 2018
Powered by FUDForum. Page generated in 0.02607 seconds
