Home » Archived » Visual Editor (VE) » VE I20050719: Unable to open a visual class
VE I20050719: Unable to open a visual class [message #98480] Wed, 20 July 2005 05:48 Go to next message
Francesc Rosés is currently offline Francesc RosésFriend
I'm testing the VE I20050719 driver and I'm unable to open a visual class
created with the VE I20050715 diver and I can open it without problems
with VE 1.0.2.2 driver.
The error message says 'An internal error occurred during: "Setup Java
Visual Editor"'.
And the log file contains:
!ENTRY org.eclipse.core.runtime 4 2 2005-07-20 07:37:00.796
!MESSAGE An internal error occurred during: "Setup Java Visual Editor".
!STACK 0
java.lang.StackOverflowError
org.eclipse.jem.internal.instantiation.base.JavaObjectInstan ce.migrate(JavaObjectInstance.java:199)
org.eclipse.jem.internal.instantiation.base.JavaObjectInstan ce.eDynamicFeatureID(JavaObjectInstance.java:264)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicGet(Basi cEObjectImpl.java:493)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:488)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:483)
org.eclipse.jem.internal.instantiation.base.JavaObjectInstan ce.getAllocation(JavaObjectInstance.java:40)
org.eclipse.ve.internal.java.codegen.java.CodeGenExpFlattene r.visit(CodeGenExpFlattener.java:80)
org.eclipse.jem.internal.instantiation.impl.PTInstanceRefere nceImpl.accept0(PTInstanceReferenceImpl.java:161)
org.eclipse.jem.internal.instantiation.impl.PTExpressionImpl .accept(PTExpressionImpl.java:65)
org.eclipse.ve.internal.java.codegen.java.CodeGenExpFlattene r.visit(CodeGenExpFlattener.java:84)
Re: VE I20050719: Unable to open a visual class [message #98538 is a reply to message #98480] Wed, 20 July 2005 09:26 Go to previous messageGo to next message
Joe Winchester is currently offline Joe WinchesterFriend
Hi Francesc,
> class created with the VE I20050715 diver and I can open it without
> problems with VE 1.0.2.2 driver.
> Visual Editor"'.
Not totally sure why the error occurs - Rich knows most about EMF and
might be able to help, but in the meantime can you use the pull down
menu option Project>Clean and see if that gets rid of the error ?
Joe Winchester
Re: VE I20050719: Unable to open a visual class [message #98593 is a reply to message #98538] Wed, 20 July 2005 10:35 Go to previous messageGo to next message
Joe Winchester wrote:
> Hi Francesc,
>> Visual Editor"'.
> Best regards,
> Joe Winchester
Hi Joe,
Unfortunately, Clean don't solves the problem. May be Rich haves a good
idea...
Francesc Rosés
Re: VE I20050719: Unable to open a visual class [message #98667 is a reply to message #98593] Wed, 20 July 2005 13:31 Go to previous messageGo to next message
Gili Mendel is currently offline Gili MendelFriend
Do you have something in the code that looks like this:
String foo = "something" ;
foo = foo.toLowerCase() // or something like this.
We have just fixed a problem, where the creation of an allocation tree went into an infinite loop (like the stack above),
because something like foo that was created using foo itself.
Re: VE I20050719: Unable to open a visual class [message #98957 is a reply to message #98667] Thu, 21 July 2005 12:43 Go to previous messageGo to next message
Hi Gili,
I think the internal code have no relation with the VE. I have, for
example, a string process to duplicate apostrophes:
String ref = getEfReferencia().getStringValue();
ref = ref.replaceAll("'", "''");
into the search() method but this have no effects over GUI.
The field efReferencia is a subclass of an abstract subclass of a
JFormattedTextField. This works fine in other dialogs.
The source code of my dialog haves aprox. 1500 lines, so is difficult
to search and/or try all string opperations.
But the VE 1.0.2.2 driver works fine, so there is a problem with
VE 1.1 drivers.
If you need inspect the code, I can send it to you by mail or I can
grant read access to my Subversion server.
Thanks for your help,
Francesc
Re: VE I20050719: Unable to open a visual class [message #99044 is a reply to message #98957] Thu, 21 July 2005 15:20 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
We just changed recently to process just about everything, before we
ignored lines like
foo = foo.toLowerCase();
But now we process these too. But we didn't realize this recursive
problem so we didn't have tests for it.
This method you showed is exactly a recursive that we were talking
about. We are trying to catch these styles and for now ignore them.
Rich Kulp
Re: VE I20050719: Unable to open a visual class [message #609113 is a reply to message #98480] Wed, 20 July 2005 09:26 Go to previous message
Hi Francesc,
> Visual Editor"'.
Joe Winchester
Re: VE I20050719: Unable to open a visual class [message #609117 is a reply to message #98538] Wed, 20 July 2005 10:35 Go to previous message
> Hi Francesc,
>> Visual Editor"'.
> Best regards,
> Joe Winchester
Hi Joe,
idea...
Francesc Rosés
Re: VE I20050719: Unable to open a visual class [message #609122 is a reply to message #98593] Wed, 20 July 2005 13:31 Go to previous message
Re: VE I20050719: Unable to open a visual class [message #609157 is a reply to message #98667] Thu, 21 July 2005 12:43 Go to previous message
Hi Gili,
VE 1.1 drivers.
Francesc
Re: VE I20050719: Unable to open a visual class [message #609168 is a reply to message #98957] Thu, 21 July 2005 15:20 Go to previous message
ignored lines like
Rich Kulp
Previous Topic:VE 1.1 RC1 does not start
Next Topic:VE 1.1 Release candidate 1 available
Current Time: Thu May 24 08:30:09 GMT 2018
Powered by FUDForum. Page generated in 0.02780 seconds
