Home » Modeling » EMF » Missing support for XML Schema documentation annotation(Documentation annotation merged to useless text)
Missing support for XML Schema documentation annotation [message #811613] Fri, 02 March 2012 15:47 Go to next message
Markus Stier is currently offline Markus StierFriend
Hi!
I'm currently using ecore XSD to parse and analyze XML schema files. These schema files make excessive use of xsd:annotations especially xsd:documentation.
The xsd:documentation entities contain source and lang attributes to distinguish between usage (label, description, technical info) and language (english, german, french). ecore xsd merges all documentation annotation into a single string. The information about language and usage is lost.
I found this mapping documentation, which describes exactly what I see (page 28):
(cannot post links)...\XMLSchemaToEcoreMapping.pdf
I this still state of the art? Anything I can do about it?
Best
Markus
Re: Missing support for XML Schema documentation annotation [message #812074 is a reply to message #811613] Sat, 03 March 2012 06:59 Go to previous messageGo to next message
Markus,
Yes, that's just how it works. You'd need to write your own
specialized XSDEcoreBuilder to get something different. What were you
hoping to do with this information?
On 02/03/2012 4:47 PM, Markus Stier wrote:
> Hi!
> xsd:documentation.
> usage is lost.
> (page 28):
> Best Markus
Re: Missing support for XML Schema documentation annotation [message #813507 is a reply to message #812074] Mon, 05 March 2012 10:54 Go to previous messageGo to next message
I'm writing a generic XML editor similar to the EMF reflective editor based on a XML Schema meta model. I want to use localized labels for the elements in the XML editor. The editor will contain a 'help' pane which will show localized information about the focused element. Localized labels and information are stored in xs:documentation annotations. I wanted to use ecore as mature component. Is there any reason (besides no need for more functionality) that ecore merges the xs:documentation elements?
Is there any chance, that an enhancement I'll provide will make it to ecore releases?
Best
Markus
Ed Merks wrote on Sat, 03 March 2012 01:59
Markus,
> Hi!
> xsd:documentation.
> usage is lost.
> (page 28):
> Best Markus
Re: Missing support for XML Schema documentation annotation [message #813549 is a reply to message #813507] Mon, 05 March 2012 12:08 Go to previous messageGo to next message
Markus,
The documentation is converted to something that EMF will use in the
generated model's Javadoc. Perhaps you can keep the original schema
around too and use the extended meta data to map back to the
corresponding components. Or you can use the same approach to populate
your own style of EAnnotations. I'm not sure what you're suggesting as
a general mapping from documentation annotations to Ecore annotations...
> xs:documentation elements? Is there any chance, that an enhancement
> Best
> Markus
>> Markus,
>> you hoping to do with this information?
>> > Hi!
>> files. > These schema files make excessive use of xsd:annotations
>> especially > xsd:documentation.
>> to > distinguish between usage (label, description, technical info)
>> and > language (english, german, french). ecore xsd merges all
>> documentation > annotation into a single string. The information
>> about language and > usage is lost.
>> see > (page 28):
>> > Best Markus
Re: Missing support for XML Schema documentation annotation [message #813683 is a reply to message #813549] Mon, 05 March 2012 15:50 Go to previous messageGo to next message
Ed,
besides being able to edit XML-files based on an XML schema I want to use ecore to create a very simplified XSD editor (manly for translation purposes). It will be crucial for me to be able to re-export the XSD-file after translating some xs:documentation elements.
A general mapping for xs:documentation would be to create an EAnnotation for each xs:documentation. The source attribute of xs:documentation will go to EAnnotation.Source. The lang attribute and the body will be converted to Details.
Very similar to how it is done with xs:appinfo. Those EAnnotations might be used or written back to their original structure, as described above.
BTW: Writing back xs:appinfo elements does not re-create appropriate xs:appinfo elements but attributes below the containing element thus modifying the structure...
Is a XSD-ecore-XSD round trip out of scope of ecore XSD? Or is this just- a bug?
Markus
Ed Merks wrote on Mon, 05 March 2012 07:08
Markus,
Re: Missing support for XML Schema documentation annotation [message #813737 is a reply to message #813683] Mon, 05 March 2012 16:56 Go to previous message
Markus,
Yes XML Schema -> Ecore -> XML Schema is definitely a lossy process.
Ecore -> XML Schema -> Ecore is designed to be non-lossy. We simply
can't and don't capture all the arbitrary DOM structure that can appear
in general (and don't capture every detail of the particle structure for
a complex type, nor key constraints).
On 05/03/2012 4:50 PM, Markus Stier wrote:
> Ed,
> described above.
> just- a bug?
> Markus
>> Markus,
>> populate your own style of EAnnotations. I'm not sure what you're
>> suggesting as a general mapping from documentation annotations to
Previous Topic:Add userinput to existing XMI
Next Topic:[Teneo] Trouble with installation
Current Time: Mon Feb 19 22:25:01 GMT 2018
Powered by FUDForum. Page generated in 0.01821 seconds
