Home » Eclipse Projects » Rich Client Platform (RCP) » no schema found for extension point
no schema found for extension point [message #811546] Fri, 02 March 2012 13:51 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising nameFriend
I have downloaded the Eclipse for RCP and RAP Developers. I have created a new project and selected not have any UI contibution.
When i add extention g.eclipse.equinox.http.registry.servlets' then get the warning
no schema found for the 'org.eclipse.equinox.http.registry.servlets' extension point
i cannot add alias and class....
how should i fix this?
Cheers
Re: no schema found for extension point [message #812395 is a reply to message #811546] Sat, 03 March 2012 19:03 Go to previous message
Hung Cuong Nguyen is currently offline Hung Cuong NguyenFriend
I got same that issue. I fixed by:
- Import eclipse.equinox.http.registry plug-in to the workspace
- Create schema folder
- Copy schema files from source (I downloaded from grepcode.com ) to schema folder.
Hope this helps.
Previous Topic:com.sun.xml.ws.client.sei.SEIStub cannot be cast to org.apache.cxf.frontend.ClientProxy
Next Topic:launching external programs for specific files
Current Time: Sat May 26 06:36:13 GMT 2018
Powered by FUDForum. Page generated in 0.01928 seconds
