Home » Newcomers » Newcomers » Cannot Load Eclipse without Wifi
Cannot Load Eclipse without Wifi [message #810097] Wed, 29 February 2012 12:35 Go to next message
Christina Collins is currently offline Christina Collins
Okay so I downloaded Eclipse Indigo yesterday and set up my environment for android application. I thought I followed everything step by step, but for some reason, I cannot load eclipse without being connected to the wifi (or ethernet). It sends me to a log file instead. Has anyone else experienced this problem?
I've attached such a log file.
[Updated on: Wed, 29 February 2012 12:37]
Report message to a moderator
Re: Cannot Load Eclipse without Wifi [message #810130 is a reply to message #810097] Wed, 29 February 2012 13:31 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
You would need to share the relevant contents of that log file to be sure.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Cannot Load Eclipse without Wifi [message #810155 is a reply to message #810130] Wed, 29 February 2012 14:13 Go to previous message
I did actually attach the log itself, but once opened, these are the contents:
!SESSION 2012-02-29 12:16:35.257 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=1.6.0_26
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/epickiwii/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/epickiwii/.eclipse_keyring -showlocation
!ENTRY org.eclipse.osgi 4 0 2012-02-29 12:16:37.269
!MESSAGE Startup error
!STACK 1
java.lang.ExceptionInInitializerError
at org.eclipse.osgi.framework.internal.core.Framework.initializeProperties(Framework.java:378)
at org.eclipse.osgi.framework.internal.core.Framework.initialize(Framework.java:200)
at org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:162)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:261)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:175)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
at java.net.InetAddress.getLocalHost(InetAddress.java:1356)
at org.eclipse.osgi.framework.internal.core.UniversalUniqueIdentifier.getIPAddress(UniversalUniqueIdentifier.java:146)
at org.eclipse.osgi.framework.internal.core.UniversalUniqueIdentifier.computeNodeAddress(UniversalUniqueIdentifier.java:113)
at org.eclipse.osgi.framework.internal.core.UniversalUniqueIdentifier.<clinit>(UniversalUniqueIdentifier.java:35)
... 12 more
Previous Topic:.eclipse folder
Next Topic:Odd context menu in Package Exporer - why? how to fix?
Current Time: Fri May 24 06:21:19 EDT 2013
Powered by FUDForum. Page generated in 0.01514 seconds
