Home » Eclipse Projects » SWTBot » Discouraged access: for the method getDefault()(I was trying to get the workspace path from where I run the Bot scripts and I get compliation errors with Activator class)
Discouraged access: for the method getDefault() [message #808707] Mon, 27 February 2012 22:15 Go to next message
Roopa V is currently offline Roopa V
I am trying to access the test files in my working directory(from where I initiate the test run) during runtime. I used the following code to get the absolute path of the file during runtime.
In short I was trying to get the workspace path from where I run the Bot scripts and used the following code.
Code snippet
@Test
public void setup1() throws Exception{
URL url = new URL(Activator.getDefault().getBundle().getEntry("/"),
"testdata/main.aql");
But I get the follwing compile errors and warnings .
Multiple markers at this line
- The method getBundle() is undefined for the type Activator
- Discouraged access: The method getDefault() from the type Activator is not accessible due to restriction on required library C:\eclipse\plugins
\org.eclipse.core.contenttype_3.4.100.v20100505-1235.jar
- Discouraged access: The type Activator is not accessible due to restriction on required library C:\eclipse\plugins
Can someone help me resolve the above errrors ?
Re: Discouraged access: for the method getDefault() [message #809913 is a reply to message #808707] Wed, 29 February 2012 07:36 Go to previous message
Atlast I got it working as i just need the absolute path of a file and the following line worked .
System.out.print(new File("testdata/textanalytics/test_files/src/main.aql").getAbsolutePath());
Please note that when you use the relative file path do not start with a '/'.
Previous Topic:how to get path for files in the plugin?
Next Topic:SWTBotMenu.click
Current Time: Sat May 25 14:35:34 EDT 2013
Powered by FUDForum. Page generated in 0.02182 seconds
