Home » Language IDEs » ServerTools (WTP) » resolveBinding return null
resolveBinding return null [message #808113] Mon, 27 February 2012 12:22 Go to next message
Alireza Missing name is currently offline Alireza Missing nameFriend
I am trying to get method binding from javascript source file. What I do is to set up the parser as follow:
ASTParser parser = ASTParser.newParser(AST.JLS3);
parser.setKind(ASTParser.K_COMPILATION_UNIT);
parser.setResolveBindings(true);
parser.setSource(source);
JavaScriptUnit unit = (JavaScriptUnit) parser.createAST(null);
and then I add a visitor to the "unit" to visit FunctionDeclaration. Inside FunctionDeclaration I try to get resolveBinding, but I get null.
Which part is wrong? How can I get method binding?
Thanks in advance,
Alireza
Re: resolveBinding return null [message #808345 is a reply to message #808113] Mon, 27 February 2012 17:23 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
What was "source" here?
> Thanks in advance,
> Alireza
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: resolveBinding return null [message #808354 is a reply to message #808345] Mon, 27 February 2012 17:40 Go to previous messageGo to next message
The source is char[] that I read from js files. I use a visitor class to visit FunctionDeclaration and it works perfectly fine. The problem is with binding that returns null.
Any thought on that?
Alireza
Re: resolveBinding return null [message #808373 is a reply to message #808354] Mon, 27 February 2012 18:09 Go to previous messageGo to next message
> with binding that returns null. Any thought on that?
> Alireza
You have to set the project on the ASTParser, or otherwise use a real
file that's in a project's Include Path--otherwise it has no idea where
to look for even the built-in runtime objects.
Nitin Dahyabhai
IBM Rational
Nitin Dahyabhai
Re: resolveBinding return null [message #808844 is a reply to message #808373] Tue, 28 February 2012 07:59 Go to previous messageGo to next message
Actually I sent another post about how to create a IJavaScriptProject and still I did not get a good answer. What would be the easiest way (assume I put all my files in a folder with name "jsfiles")?
Alireza
Re: resolveBinding return null [message #809283 is a reply to message #808844] Tue, 28 February 2012 17:25 Go to previous messageGo to next message
I added the folder with javascript files to my include path in eclipse but still the bindings are null.
Alireza
Re: resolveBinding return null [message #1041471 is a reply to message #808113] Mon, 15 April 2013 06:29 Go to previous message
Elham M is currently offline Elham MFriend
I have a same problem!
I can read function using "FunctionDeclaration" but I want to access to variables in my java script code. I use "VariableDeclaration"! It doesn't work, and returns null.
Can you help me.
Previous Topic:Creating a new StructuredEditor
Next Topic:How to find links pointing to document
Current Time: Sun Jan 21 07:10:16 GMT 2018
Powered by FUDForum. Page generated in 0.01675 seconds
