Re: Load 3,4 GB 64 bits dump on 32 bits [message #8770 is a reply to message #8744] |
Wed, 11 February 2009 18:02  |
Andreas Buchen Messages: 121 Registered: July 2009 |
> I can open the dump file on MAT and open the dominator tree, but opening
> the leak suspects report, trigger a new parser operation and after some
> hours, there is an OOME (java heap space)
Strange. If the MAT versions are identical on both machines, then parsing
should not happen again. The leak suspect report is using nothing special
here.
Are you sure that it is deleted the index files and re-parsing?
However, depending on your leak, the leak report itself might have a
problem. We have seen in the passed, that certain type of leaks are
problematic. Therefore we added some sampling. Maybe we need to add some
more. You could help by taking a thread dump during the long operation.
> Is there any way to generate leak suspects on command line, as
> ParseHeapDump.sh ?
Yes. The syntax is strange, but add "org.eclipse.mat.api:suspects"
(without ") as an additional argument after the heap dump.
Similar to
http://wiki.eclipse.org/index.php/MemoryAnalyzer/FAQ#How_to_ run_on_64bit_VM_while_the_native_SWT_are_32bit
Andreas.
FUDForum. Page generated in 0.01498 seconds
