Home » Modeling » EMF » Saving a resource to a new uri
Saving a resource to a new uri [message #805942] Fri, 24 February 2012 10:21 Go to next message
Klaus S. is currently offline Klaus S.Friend
Hi all,
I'd like to save a model resource along with its referenced resources to a new uri. My trouble is, the references of the model are pointing after saving still to the original resource files. What I'm doing wrong?
The code is posted below:
public boolean saveResource(Resource res, String path) {
    res.setURI(URI.createFileURI(path));
    Map<Object, Object> defaultSaveOptions = getSaveOptions();
    // save additional resources (profiles, ...)
    if (res.getResourceSet() != null) {
        for (Resource resTmp : res.getResourceSet().getResources()) {
	    if (!resTmp.getURI().path().equals(res.getURI().path())) {
               resTmp.setURI(res.getURI().trimSegments(1)
                .appendSegment(resTmp.getURI().lastSegment()));
		try {
		   resTmp.save(Collections.EMPTY_MAP);
		} catch (IOException e) {
			e.printStackTrace();
    try {
        res.save(defaultSaveOptions);
	return false;
    return true;
Re: Saving a resource to a new uri [message #805962 is a reply to message #805942] Fri, 24 February 2012 10:49 Go to previous messageGo to next message
Christian,
Comments below.
On 24/02/2012 11:21 AM, Christian S. wrote:
> Hi all,
Have all the proxies to this resource been resolved? If there are any
unresolved proxies they will resolve to the old name. You can use
EcoreUtil.resolveAll to ensure they're all resolved.
Is this a very expensive way of saying resTemp != res?
These resources don't have references to each other, right? Only to the
resource you renamed earlier?
> try {
> try {
> return false;
> return true;
Re: Saving a resource to a new uri [message #806878 is a reply to message #805962] Sat, 25 February 2012 16:49 Go to previous message
Ed Merks wrote on Fri, 24 February 2012 05:49
EcoreUtil.resolveAll ... thats it. thanks!
Previous Topic:[EMF.Edit] How to delete a reference/object using RemoveCommand, my approach correct?
Next Topic:EMF Compare and OPTION_ZIP ?
Current Time: Mon Jun 18 10:03:49 GMT 2018
Powered by FUDForum. Page generated in 0.01711 seconds
