Re: couldn' open kernel32.lib [message #808044 is a reply to message #806217] |
Mon, 27 February 2012 10:22 |
Axel Mueller Messages: 1973 Registered: July 2009 |
Pierre-Jean Hardibo wrote on Fri, 24 February 2012 19:03Axel Mueller wrote on Fri, 24 February 2012 04:06see wiki.eclipse.org/CDT/User/FAQ#Adding_C.2FC.2B.2B_External_Libraries
Yes it works but i have a new error message :
LINK : fatal error LNK1104: couldn't open file 'C:\Program.obj'
It's strange that it try to open such a file.
Note: i'm really a beginner.
Thanks for your help.
The compiler creates object files from your source code. The linker then "glues" these object files together to create an executable. Usually these object files are created in your workspace and not in the root folder of drive C:. I guess you somehow broke your project setup. However, I have not enough info to help you.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
FUDForum. Page generated in 0.03524 seconds
