Home » Eclipse Projects » Plugin Development Environment (PDE) » When is a class "API"?
When is a class "API"? [message #805283] Thu, 23 February 2012 15:26 Go to next message
Thorsten Meinl is currently offline Thorsten MeinlFriend
Member
Another question regarding API tooling: when does the checker consider a
class as being API? We have some classes that changed between the
baseline but they are meant to be used only inside the plugin. Even
flagging them with @noextend and @noinstantiate still gives error on the
MANIFEST that the minor version should be increased because of an API
change. How do I make a class non-API?
Thorsten
Re: When is a class "API"? [message #805384 is a reply to message #805283] Thu, 23 February 2012 17:41 Go to previous message
Member
OK, I can probably answer this myself now: everything is API except if
you add x-internal:=true to the Export-Package declaration in the
manifest. Is this correct?
Previous Topic:API Tooling: is no longer API
Next Topic:Strange error on Mac build
Current Time: Sun Apr 22 03:08:16 GMT 2018
Powered by FUDForum. Page generated in 0.02188 seconds
