Home » Eclipse Projects » Remote Application Platform (RAP) » using org.eclipse.rwt.widgets.FileUpload, how to get the selected file path
using org.eclipse.rwt.widgets.FileUpload, how to get the selected file path [message #804946] Thu, 23 February 2012 07:09 Go to next message
ocean xue is currently offline ocean xueFriend
using org.eclipse.rwt.widgets.FileUpload, how to get the selected file path.
now I can only use FileUpload.getFileName () Get the file name.
Re: using org.eclipse.rwt.widgets.FileUpload, how to get the selected file path [message #804995 is a reply to message #804946] Thu, 23 February 2012 08:13 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
why do you need the complete path of the selected file on the client? I
think that due to security reasons, its not possible to get the full
path on the client when HTML browse button is used.
Best,
Ivan
> path.
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: using org.eclipse.rwt.widgets.FileUpload, how to get the selected file path [message #805004 is a reply to message #804995] Thu, 23 February 2012 08:25 Go to previous messageGo to next message
Get the full path, I want to read this file to the database
Re: using org.eclipse.rwt.widgets.FileUpload, how to get the selected file path [message #805105 is a reply to message #805004] Thu, 23 February 2012 10:39 Go to previous messageGo to next message
You can't read this file directly from the client without uploading it
to the server first. That's why the full *client* path is useless. Did
you write your custom file upload handler? Probably, the
"org.eclipse.rap.rwt.supplemental.filedialog" or
"org.eclipse.rap.rwt.supplemental.fileupload" bundles from the incubator
is what you are looking for.
HTH,
Ivan
Ivan Furnadjiev
Re: using org.eclipse.rwt.widgets.FileUpload, how to get the selected file path [message #805327 is a reply to message #805004] Thu, 23 February 2012 16:31 Go to previous message
Ralf Sternberg is currently offline Ralf SternbergFriend
You don't get the full path in all browsers. So we cut off the path to
provide the same results in all browsers. As Ivan said, you should not
rely on the path - it belongs entirely to the user.
Ralf
Ralf Sternberg
Previous Topic:Accessing SessionSingleton from thread
Next Topic:About TitleAreaDialog ButtonBar
Current Time: Tue Apr 24 03:09:13 GMT 2018
Powered by FUDForum. Page generated in 0.02618 seconds
