Home » Eclipse Projects » EGit » [EGIT 1.3] : NPE at import
[EGIT 1.3] : NPE at import [message #804437] Wed, 22 February 2012 11:16 Go to next message
Esteban Dugueperoux is currently offline Esteban Dugueperoux
Since I have EGit updated to 1.3, I have a NPE when importing a project
with the Git import wizard, it is a known issue :
org.eclipse.egit.ui.internal.clone.GitImportWizard$1.setVisible(GitImportWizard.java:63)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1260)
at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1239)
at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1228)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1226)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:915)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:428)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.ui.internal.handlers.WizardHandler$Import.executeHandler(WizardHandler.java:150)
org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
org.eclipse.ui.internal.actions.CommandAction.run(CommandAction.java:171)
org.eclipse.ui.actions.ImportResourcesAction.run(ImportResourcesAction.java:97)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEvent(BaseSelectionListenerAction.java:168)
org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Re: [EGIT 1.3] : NPE at import [message #813760 is a reply to message #804437] Mon, 05 March 2012 12:14 Go to previous message
Kevin Sawicki is currently offline Kevin Sawicki
Member
I believe this was fixed today as part of Bug 372982 and should be available in the next nightly.
Previous Topic:EGit 1.3.0 causing problems with Indigo 3.7.2 on Solaris X86
Next Topic:Newest JGit broken?
Current Time: Sun May 19 04:14:48 EDT 2013
Powered by FUDForum. Page generated in 0.03287 seconds
