Home » Eclipse Projects » BIRT » Importing .jar files into BIRT(Can not seem to load .jar files into BIRT)
Importing .jar files into BIRT [message #803330] Tue, 21 February 2012 07:43 Go to next message
andrew smith is currently offline andrew smithFriend
Member
Hi, all:
I hope this post finds you all well. What is the best way to include .jar files into BIRT project thus making its classes visible to the scipt?
I have some logic contained in Java .jar files ie bunch of data processing classes that I would like to invoke through BIRT. They all work flawlessly in Java. I ran them in pure Java, Matlab, Netbeans, etc.
I use the importPackage command:
importPackage(Packages.database.connectors.jdbc.MsSQLserver);
however, I get the following message:
Function importPackage must be called with a package; had "[JavaClass database.connectors.jdbc.MsSQLserver]" instead. (/report/method[@name="initialize"]#1)
I added .jar file already as an external JAR (ProjectProperies->Classpath ). Also I tried sticking it in the /WEB-INF/lib folder as well as using the Import Wizard. Same error prevails...
What am I doing wrong?
Thank you,
Andrew
Re: Importing .jar files into BIRT [message #803695 is a reply to message #803330] Tue, 21 February 2012 17:06 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Take a look at this:
http://birtworld.blogspot.com/2009/12/birt-designer-classpath-changes.html
That post shows the preference to use in the designer. You can also
click on resources for the report and add a jar there, but the jar will
have to be available in the resource folder in the designer and deployed
viewer
If you added the jar to the designer classpath,
when you deploy the report to the viewer (3.7 or >) just put the jar in
the web-inf/lib.
Jason
On 2/21/2012 2:43 AM, andrew smith wrote:
> Hi, all:
> prevails...
> Thank you,
> Andrew
Re: Importing .jar files into BIRT [message #803870 is a reply to message #803695] Tue, 21 February 2012 23:28 Go to previous messageGo to next message
Member
Hello Jason,
Thank you for your advice. Let me go over the items just to make sure I understand
1) Followed the instructions at birtworld.blogspot.com/2009/12/birt-designer-classpath-changes.html. I created a custom folder for all of my .jar files and placed the path to the folder using the PROJECT PROPERTIES->CLASSPATH
Result: the class is not being imported
2) I placed the .jar file directly into the /WEB-INF/lib folder.
3) Imported .jar file through the resources window.
I am almost certain that the error that I am making is so trivial, that I can not seem to find it.
Is there a 'sure' way to import java classes into BIRT? What am I doing wrong?
Andrew
Re: Importing .jar files into BIRT [message #803906 is a reply to message #803870] Wed, 22 February 2012 00:45 Go to previous messageGo to next message
Adding a class folder only works for folders that contain classes not
jars I believe. Take a look at the attached workspace. Unzip it and
open the workspace in Eclipse. I have two projects in it that show how
to include a simple jar with the following code:
package my.simple.example;
public class TestClass {
private String testString="My String";
public String getTestString() {
return testString;
public void setTestString(String testString) {
this.testString = testString;
When you look at the preferences be sure to click on the configure
project specific configuration link. One shows how to include the jar
using the classpath preference and the other shows how to include a jar
in the resource folder.
Jason
On 2/21/2012 6:28 PM, andrew smith wrote:
> Hello Jason,
> understand
> I can not seem to find it. Is there a 'sure' way to import java classes
> Andrew
Re: Importing .jar files into BIRT [message #804075 is a reply to message #803906] Wed, 22 February 2012 06:55 Go to previous message
Member
Jason,
Thank you VERY MUCH for an example!! I found my error!! Stupid me, I was importing .jar file incorrectly.
Instead of importing a package and then using a class from there, I was importing the class directly. When I corrected my mistake, things started to work. Smile
If you are in Chicago, let me know. Beer is on me.
Many thanks!!
Previous Topic:Data set from SCTM
Next Topic:dynamic hyperlinking in birt 3.7.1.v20110905-809u7NFT0z0-TWCm5MjN7w
Current Time: Fri May 25 05:36:27 GMT 2018
Powered by FUDForum. Page generated in 0.01668 seconds
