Home » Newcomers » Newcomers » errorr on eclipse and tomcat7(eclipse and tomcat 7 server)
errorr on eclipse and tomcat7 [message #802029] Sun, 19 February 2012 09:29 Go to next message
ameet yadav is currently offline ameet yadavFriend
hi everyone , i am trying to run dynamic web program on eclipse(Indigo) with apache-tomcat 7.0.25 but getting following error :
when i click on run as -> server
Could not load the Tomcat server configuration at /Servers/Tomcat v7.0 Server at localhost-config. The configuration may be corrupt or incomplete.
please any advise what is wrong .
what i should have to do to overcome this error?
my OS is Ubuntu 10.10
Re: errorr on eclipse and tomcat7 [message #802259 is a reply to message #802029] Sun, 19 February 2012 17:43 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
Suggestion: Try setting up a private Tomcat installation. See
http://www.javahotchocolate.com/tutorials/setup-tomcat.html
Whatever the actual reason for your problem, following what's here will
probably leave you with a working installation.
Re: errorr on eclipse and tomcat7 [message #802654 is a reply to message #802259] Mon, 20 February 2012 08:44 Go to previous messageGo to next message
Hi Russell,
thanks for suggestion, i have followed the similar steps from "http://www.javahotchocolate.com/tutorials/setup-tomcat.html" to set up tomcat on eclipse ,
but still there is one error:
"Cannot create a server using the selected type"
Re: errorr on eclipse and tomcat7 [message #802695 is a reply to message #802654] Mon, 20 February 2012 10:13 Go to previous messageGo to next message
Since three days i was trying the same thing is running web application as a server under Tomcat but got errors ,
today i solved it i don't know what was wrong but what i did is
i removed the eclipse and tomcat and
copied the tomcat7 and eclipse tar files in different folder and extracted in same location. and it worked !!!
[Updated on: Mon, 20 February 2012 10:40]
Report message to a moderator
Re: errorr on eclipse and tomcat7 [message #1043377 is a reply to message #802029] Wed, 17 April 2013 16:17 Go to previous message
Saul P is currently offline Saul PFriend
In my case, Eclipse had not super user rights.
so he could not start tomcat. (the path where was placed tomcat was /usr/local/tomcat)
I can resolve that, placing my tomcat file conteiner in home (/home/tomcat/ )
Maybe this is not the best way to do this, but I have been able to resolve this (It supose that we can create and give some rights to files, in this case, right to eclipse to startup and shutdown tomcat, but I am newbi in linux, so I dont tried to make me the heroe Smile )
Previous Topic:Eclipse crashes with an import of an existing java project (debian)
Next Topic:Legend for icons
Current Time: Mon Feb 26 01:37:36 GMT 2018
Powered by FUDForum. Page generated in 0.03353 seconds
