Home » Modeling » TMF (Xtext) » Check eContainer for equality
Check eContainer for equality [message #800044] Thu, 16 February 2012 16:13 Go to next message
Alex G is currently offline Alex GFriend
Member
Hi @all!
I want to traverse my AST from my DSL for scoping reasons. I have a node somewhere and want to go up (in direction to the root) to some (grand)parent. I know the type of the (grand)parent. Since I make these calls more often, I have a generic function in order to search for the parent (in XTend):
def getParentOfType(EObject obj, Class clazz) {
   var parent = obj;
   while(!parent.eClass.instanceClass.equals(clazz))
        parent = parent.eContainer
   parent
Surely I could also call something like and work on nodes
val parent = NodeModelUtils::getNode(obj).semanticElement
The question is: Is there an easier way to check eContainers for type equality with a generic eClass? Or is the method above the "most" generic and short one?
The problem is that if call this function I have to write something like:
val x = some_eObject.getParentOfType(typeof(some_eClass)) as some_eClass
and this is not nice in my opinion.
Furthermore the function above returns null if no parent eContainer along the tree to the root is found. Since I use this function in local scope methods, I would need to return therefore not null but IScope::NULLSCOPE. Is there a way to return the NULLSCOPE by default, if null would have been returned?
Re: Check eContainer for equality [message #800076 is a reply to message #800044] Thu, 16 February 2012 16:50 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
What about using getContainerOfType in Xtexts ECoreUtil2
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
Re: Check eContainer for equality [message #801038 is a reply to message #800076] Fri, 17 February 2012 21:02 Go to previous message
Member
Cool, didn't know about these utilities. Thank you.
Previous Topic:Custom Formatter - minimising impact when grammar changes?
Next Topic:Problems writing Scope provider for enumeration literals
Current Time: Sun Apr 22 20:29:19 GMT 2018
Powered by FUDForum. Page generated in 0.01813 seconds
