Home » Eclipse Projects » BIRT » Eclipse BIRT Designer Crahses
Eclipse BIRT Designer Crahses [message #797725] Mon, 13 February 2012 21:02 Go to next message
Shane Allred is currently offline Shane AllredFriend
I have tried 3 different eclipse installations of BIRT and have not really found one that is stable. Currently I have switched to the 64 bit version and occasionally it will just crash. When I go to my workspace logs I see the following errors:
!ENTRY org.eclipse.ui 4 4 2012-02-13 13:32:12.910
!MESSAGE An internal error has occurred.
!STACK 0
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4308)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Display.internal_new_GC(Display.java:2673)
at org.eclipse.swt.graphics.Device.getDepth(Device.java:447)
at org.eclipse.swt.widgets.Display.getIconDepth(Display.java:1886)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.java:976)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.java:1066)
at org.eclipse.jface.window.Window.configureShell(Window.java:373)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.configureShell(ProgressMonitorDialog.java:392)
at org.eclipse.jface.window.Window.createShell(Window.java:502)
at org.eclipse.jface.window.Window.create(Window.java:430)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.open(ProgressMonitorDialog.java:678)
at org.eclipse.ui.internal.progress.ProgressManager$6.runInUIThread(ProgressManager.java:1017)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
I've tried tuning the memory in eclipse.ini file. My current settings are as follows:
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.100.v20110502
-product
org.eclipse.epp.package.reporting.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms256m
-Xmx2048m
Re: Eclipse BIRT Designer Crahses [message #797783 is a reply to message #797725] Mon, 13 February 2012 22:06 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
You may want to open a bugzilla for this. I use the allinone download
and I hardly ever get a crash. I use Java 6, but I doubt that will make
a difference.
Jason
> !STACK 0
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> are as follows:
> -startup
> --launcher.library
> -product
> openFile
> 256M
> -showsplash
> 256m
> openFile
> -vmargs
> -Xms256m
> -Xmx2048m
> Thanks
Previous Topic:Problem with Library Item and Datasource
Next Topic:Report Legend
Current Time: Wed Jan 17 01:46:33 GMT 2018
Powered by FUDForum. Page generated in 0.01994 seconds
