Home » Eclipse Projects » EclipseLink » Validation to DDL constraint
Validation to DDL constraint [message #795060] Fri, 10 February 2012 02:31 Go to next message
Eduardo Frazão is currently offline Eduardo FrazãoFriend
Hi all. Im new on Eclipselink (come from Hibernate). If i use the hibernate jsr 303 implementation, constraints like @NotNull or @Size will be translated to ddl schema during database creation or i will need to write this constraints in a @Column to?
thanks...
Re: Validation to DDL constraint [message #795725 is a reply to message #795060] Fri, 10 February 2012 21:23 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
EclipseLink's DDL generation uses JPA annotations and xml, so you will need to put constraints and sizes within the @Column annotations.
Re: Validation to DDL constraint [message #795774 is a reply to message #795725] Fri, 10 February 2012 23:01 Go to previous message
Thanks @Chris Delahunt.
As Hibernate can use the Validation API to create database schema, I only wanna sure that Eclipselink do it or no!
But no problem! I will write the database constraints in JPA too!
Att,
Eduardo Frazão
Previous Topic:org.eclipse.persistence.exceptions.ValidationException
Next Topic:Relative Path to JDBC-Url
Current Time: Thu Apr 26 02:14:49 GMT 2018
Powered by FUDForum. Page generated in 0.01835 seconds
