Home » Modeling » Epsilon » How to migrate complex models(Flock fails to recognize objects with a foreign metamodel)
How to migrate complex models [message #794125] Wed, 08 February 2012 23:46 Go to next message
Mark Tippetts is currently offline Mark TippettsFriend
I have a metamodel that references several other metamodels. I want to evolve the metamodel to a new version. This works with a simple metamodel, i.e. one containing no references to other metamodels. But it breaks when I try to migrate models based on complex metamodels, i.e. ones with dependencies.
Let's assume the simplest possible case: The only change is to the NSURI, so I have an empty Flock file.
Simple example:
Original metamodel:
@namespace(uri="http://simplemetamodel/1.0", prefix="simplemetamodel")
package simplemetamodel;
class Something {
  attr String name;
Migrated Metamodel:
@namespace(uri="http://simplemetamodel/2.0", prefix="simplemetamodel")
class Something {
  attr String name;
Original model:
@Spec {
	metamodel "http://simplemetamodel/1.0" {
		nsUri: "http://simplemetamodel/1.0"
package  {
	Something "Simple" {
Migrated model:
@Spec {
	metamodel "http://simplemetamodel/2.0" {
		nsUri: "http://simplemetamodel/2.0"
package  {
Complex example:
External metamodel:
@namespace(uri="http://externalmetamodel/1.0", prefix="externalmetamodel")
package externalmetamodel;
class Peer {
  attr String name;
Original metamodel:
@namespace(uri="http://complexmetamodel/1.0", prefix="complexmetamodel")
package complexmetamodel;
import "platform:/resource/flock.update.example/model/ExternalMetamodel.ecore";
class Something {
  attr String name;
  ref externalmetamodel.Peer referenced;
Migrated metamodel:
@namespace(uri="http://complexmetamodel/2.0", prefix="complexmetamodel")
class Something {
  attr String name;
External model:
@Spec {
	metamodel "http://externalmetamodel/1.0" {
		nsUri: "http://externalmetamodel/1.0"
package  {
	Peer "Foo" {
Original model:
@Spec {
	metamodel "http://complexmetamodel/1.0" {
		nsUri: "http://complexmetamodel/1.0"
package  {
	Something "Complex" {
		referenced: Peer "PeerOne.model#_dMKaUFKZEeGB5seTnKLM5Q"
Migrated model:
@Spec {
	metamodel "http://complexmetamodel/2.0" {
		nsUri: "http://complexmetamodel/2.0"
	}metamodel "http://externalmetamodel/1.0" {
package  {
	Peer "Foo" {
package  {
As you can see, that's all wrong. Since the syntax of Flock remains somewhat undocumented, I'm hoping there's some simple workaround?
Mark Tippetts
Re: How to migrate complex models [message #794759 is a reply to message #794125] Thu, 09 February 2012 17:13 Go to previous message
Louis Rose is currently offline Louis RoseFriend
Hi Mark,
I'm sorry to read that you're having a problem with Flock. Thanks for providing an example of the problem behaviour; I'm sure I can help you to arrive at a solution.
I agree that Flock's current behaviour in this case doesn't seem to be at all sensible. I shall investigate, and get back to you tomorrow morning.
More soon,
Louis.
Previous Topic:[EOL][ETL] Specify Target Model during runtime
Next Topic:About ETL rules
Current Time: Sun Feb 18 11:17:41 GMT 2018
Powered by FUDForum. Page generated in 0.01369 seconds
