Home » Eclipse Projects » GEF » RoundedRectangle
RoundedRectangle [message #92448] Thu, 04 September 2003 16:40 Go to next message
Alex Selkov is currently offline Alex SelkovFriend
Member
RoundedRectangle depicts incorrectly.
I also found useful if setLineWidth(0) has the same effect as
setOutline(false). Is it possible to incorporate such behavior into the
Shape?
Index: Shape.java
RCS file: /home/tools/org.eclipse.draw2d/src/org/eclipse/draw2d/Shape. java,v
retrieving revision 1.4
diff -u -r1.4 Shape.java
--- Shape.java 3 Jun 2003 19:05:55 -0000 1.4
+++ Shape.java 4 Sep 2003 16:35:44 -0000
@@ -25,6 +25,7 @@
private boolean
fill = true,
outline = true,
+ suppressOutline = false,
xorFill,
xorOutline;
@@ -89,7 +90,7 @@
graphics.setXORMode(xorFill);
fillShape(graphics);
- if (outline) {
+ if (outline && !suppressOutline) {
graphics.setXORMode(xorOutline);
graphics.setLineStyle(lineStyle);
graphics.setLineWidth(lineWidth);
@@ -103,7 +104,7 @@
- if (outline) {
@@ -147,6 +148,11 @@
if (lineWidth == w)
return;
lineWidth = w;
+ if (lineWidth == 0) {
+ suppressOutline = true;
+ } else {
+ suppressOutline = false;
repaint();
import org.eclipse.draw2d.ColorConstants;
import org.eclipse.draw2d.Ellipse;
import org.eclipse.draw2d.Figure;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.Label;
import org.eclipse.draw2d.LightweightSystem;
import org.eclipse.draw2d.LineBorder;
import org.eclipse.draw2d.Polyline;
import org.eclipse.draw2d.RectangleFigure;
import org.eclipse.draw2d.RoundedRectangle;
import org.eclipse.draw2d.geometry.Dimension;
import org.eclipse.draw2d.geometry.Point;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.widgets.Shell;
public class Demo4 {
private static final int GAP = 20;
private static final Dimension SIZE = new Dimension(75, 50);
private static final Dimension CORNER = new Dimension(30, 25);
private static final int COUNT = 20;
public static void main(String args[]) {
Shell shell = new Shell();
shell.setSize(800, 750);
shell.open();
shell.setText("Figures");
LightweightSystem lws = new LightweightSystem(shell);
IFigure panel = new Figure();
lws.setContents(panel);
final Color BG_COLOR = ColorConstants.white;
final Color PANEL_COLOR = ColorConstants.blue;
final Color FG_COLOR = ColorConstants.red;
final Color GRID_COLOR = ColorConstants.black;
panel.setBackgroundColor(PANEL_COLOR);
panel.setOpaque(true);
for (int i = 0; i < COUNT; i++) {
if (i % 2 == 0) {
Polyline p = new Polyline();
p.setForegroundColor(GRID_COLOR);
p.setStart(
new Point(0, GAP + (GAP + SIZE.height) * (i / 2) - 1));
p.setEnd(
new Point(
GAP + 8 * (GAP + SIZE.width),
panel.add(p);
p = new Polyline();
p.setStart(new Point(0, (GAP + SIZE.height) * (i / 2 + 1) - 1));
p.setEnd(
new Point(
panel.add(p);
RoundedRectangle rr = new RoundedRectangle();
rr.setBackgroundColor(BG_COLOR);
rr.setForegroundColor(FG_COLOR);
rr.setCornerDimensions(CORNER);
rr.setSize(SIZE);
rr.setLineWidth(i);
rr.setLocation(
new Point(
GAP + (i % 2) * (SIZE.width + GAP),
GAP + (i / 2) * (SIZE.height + GAP)));
panel.add(rr);
RectangleFigure rf = new RectangleFigure();
rf.setBackgroundColor(BG_COLOR);
rf.setForegroundColor(FG_COLOR);
rf.setSize(SIZE);
rf.setLineWidth(i);
rf.setLocation(
new Point(
GAP * 3 + SIZE.width * 2 + (i % 2) * (SIZE.width + GAP),
panel.add(rf);
Ellipse el = new Ellipse();
el.setBackgroundColor(BG_COLOR);
el.setForegroundColor(FG_COLOR);
el.setSize(SIZE);
el.setLineWidth(i);
el.setLocation(
new Point(
GAP * 5 + SIZE.width * 4 + (i % 2) * (SIZE.width + GAP),
panel.add(el);
Label l = new Label("Label #" + i);
l.setOpaque(true);
l.setSize(SIZE);
if (i != 0)
l.setBorder(new LineBorder(i));
l.setLocation(
new Point(
GAP * 7 + SIZE.width * 6 + (i % 2) * (SIZE.width + GAP),
panel.add(l);
Display display = Display.getDefault();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
Re: RoundedRectangle [message #92464 is a reply to message #92448] Thu, 04 September 2003 16:48 Go to previous messageGo to next message
Member
"Alex Selkov" <as@empproject.com> wrote in message
news:bj7psm$g6d$1@eclipse.org...
And one pixel smaller comparing with other draw2d figures...
Re: RoundedRectangle [message #92494 is a reply to message #92464] Thu, 04 September 2003 17:48 Go to previous messageGo to next message
Eric Bordeau is currently offline Eric BordeauFriend
We draw RoundRectangle the same way we draw RectangleFigure. It has to
do with the way SWT's GC draws draws rounded rectangles. There's a
thread on the SWT newsgroup (GC#drawRoundRectangle() Eclipse R3.0 !=
R2.1) discussing this problem. Here's an excerpt:
<quote>
The width and height of drawRoundRectangle() was changed in 3.0 to make
it consistent with other drawing operations and other platforms.
The width and height of the rounded rectangle should be the same as the
normal rectangle (drawn with drawRectangle()). The same should be true
with fillRoundRectangle() and fillRectangle().
</quote>
Re: RoundedRectangle [message #92509 is a reply to message #92448] Thu, 04 September 2003 18:03 Go to previous messageGo to next message
Line width of 0 is a valid line width. Contrary to common sense, width of 0
is still visible, and it has slightly different behavior than line width of
1. There is a bug open on this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=38073
Thanks for the suggestion,
-Randy
> Shape?
> Index: Shape.java
> RCS file:
> @@ -25,6 +25,7 @@
> private boolean
> fill = true,
> outline = true,
> xorFill,
> xorOutline;
> @@ -89,7 +90,7 @@
> - if (outline) {
> @@ -103,7 +104,7 @@
> - if (outline) {
> if (lineWidth == w)
> return;
> lineWidth = w;
> + } else {
> repaint();
> import org.eclipse.swt.widgets.Display;
> shell.open();
> if (i % 2 == 0) {
> p.setStart(
> p.setEnd(
> new Point(
> panel.add(p);
> p = new Polyline();
> p.setEnd(
> new Point(
> panel.add(p);
> rr.setSize(SIZE);
> rr.setLineWidth(i);
> rr.setLocation(
> new Point(
> panel.add(rr);
> rf.setSize(SIZE);
> rf.setLineWidth(i);
> rf.setLocation(
> new Point(
> panel.add(rf);
> el.setSize(SIZE);
> el.setLineWidth(i);
> el.setLocation(
> new Point(
> panel.add(el);
> l.setOpaque(true);
> l.setSize(SIZE);
> if (i != 0)
> l.setLocation(
> new Point(
> panel.add(l);
> display.sleep();
Re: RoundedRectangle [message #92625 is a reply to message #92494] Thu, 04 September 2003 20:00 Go to previous messageGo to next message
Member
OK. I can see that minor problem with figure size solved in 3.0.
But what about problem with RoundedRectangle if LineWidth > 1? See picture
attached.
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:bj7tsd$7e5$1@eclipse.org...
> <quote>
> </quote>
  • Attachment: image002.jpg
    (Size: 69.71KB, Downloaded 70 times)
Re: RoundedRectangle [message #92641 is a reply to message #92509] Thu, 04 September 2003 20:07 Go to previous message
Member
If so, that means that draw2d renders figures with width 0 incorrectly (as
shown in example above - missing left and lower part of the rectangle
outline).
Actually, for my taste using width = 0 as optimisation hint (only at
specific platform) is misleading.
as
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bj7unh$lfm$1@eclipse.org...
0
of
> -Randy
> > Shape?
> > Index: Shape.java
> > RCS file:
> > @@ -25,6 +25,7 @@
> > private boolean
> > fill = true,
> > outline = true,
> > xorFill,
> > xorOutline;
> > @@ -89,7 +90,7 @@
> > - if (outline) {
> > @@ -103,7 +104,7 @@
> > - if (outline) {
> > if (lineWidth == w)
> > return;
> > lineWidth = w;
> > + } else {
> > repaint();
> > shell.open();
> > if (i % 2 == 0) {
> > p.setStart(
> > p.setEnd(
> > new Point(
> > panel.add(p);
> > p = new Polyline();
> > p.setEnd(
> > new Point(
> > panel.add(p);
> > rr.setSize(SIZE);
> > rr.setLineWidth(i);
> > rr.setLocation(
> > new Point(
> > panel.add(rr);
> > rf.setSize(SIZE);
> > rf.setLineWidth(i);
> > rf.setLocation(
> > new Point(
> > panel.add(rf);
> > el.setSize(SIZE);
> > el.setLineWidth(i);
> > el.setLocation(
> > new Point(
> > panel.add(el);
> > l.setOpaque(true);
> > l.setSize(SIZE);
> > if (i != 0)
> > l.setLocation(
> > new Point(
> > panel.add(l);
> > display.sleep();
Previous Topic:How can I create objects int the outline viewer without figure?
Next Topic:How can I stretch my contents figure to a preferred size?
Current Time: Thu Feb 22 17:26:09 GMT 2018
Powered by FUDForum. Page generated in 0.02075 seconds
