Home » Modeling » OCL » Is it possible to modify condition collections of cycle?
Is it possible to modify condition collections of cycle? [message #786027] Sun, 29 January 2012 22:42 Go to next message
Patricia Espada is currently offline Patricia EspadaFriend
Member
I'm trying to understand some property of cycles in OCL. I want to change a variable that is subject of a cycle condition, in that same cycle. Maybe with and example it's better to understand. I want to determine the depth of a tree, doing something similar to this:
Stack s = new Stack();
    s.push(head);
    while(s.count > 0)
    	Node temp = s.pop();
    	if (temp != NULL)
    		if (s.Value == val)
    			return s.Depth;
    		else
    			s.push(temp.Left);
    			s.push(temp.Right);
it is possible to do this in OCL? and if it is, is it possible to use this in OCLInEcore?
Re: Is it possible to modify condition collections of cycle? [message #786253 is a reply to message #786027] Mon, 30 January 2012 07:09 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
This is a FAQ. For which I've added
http://wiki.eclipse.org/MDT/OCL/FAQ#How_do_I_modify_an_Object_in_OCL.3F.
An approximate equivalent to your example might be possible in OCL using
iterate to continually create new 'Stack's. (The new OCL uses
accumulators behind the scenes for iterate so old collections are reused.)
A replica of your code is possible with recursion. (Optimisation to
reuse of stale collections awaits implementation).
package Espada : pfx = 'platform:/resource/Activity/Espada.ecore' {
class Node {
property value : Integer;
property left : Node;
property right : Node;
operation find(target : Integer) : Integer
body: recurse(Sequence{self}, target);
operation recurse(stack : Node[0..*]{ordered,!unique}, target :
Integer) : Integer
body:
if stack->notEmpty()
then 0
else
let peek : Node = stack->last() in
if peek.value = target
then stack->size()
else
recurse(stack->excluding(peek)->append(peek.left)->append(peek.right),
target)
endif
endif;
Ed Willink
On 29/01/2012 22:42, Patricia Espada wrote:
> Hello,
> s.push(head);
> while(s.count > 0)
> if (temp != NULL)
> if (s.Value == val)
> return s.Depth;
> else
> s.push(temp.Left);
> s.push(temp.Right);
> this in OCLInEcore?
Re: Is it possible to modify condition collections of cycle? [message #786471 is a reply to message #786253] Mon, 30 January 2012 13:24 Go to previous messageGo to next message
Member
Hello
My interest in the example I've shown is that is done with no recursive function. And with iterate I really can not see how to do it. You say to create multiple Stacks within the iterate? But how can declare three variables in an iterate?
let s: Set(Integer) = Set{1,2,3} in s->iterate(i: Integer; sum: Integer = 0; s = s->including(4) | ...)
This is not possible?!
Re: Is it possible to modify condition collections of cycle? [message #786643 is a reply to message #786471] Mon, 30 January 2012 17:10 Go to previous messageGo to next message
You can declare multiple variables with Tuples.
I wrote 'might be possible' since I've not really studied your code. In
order to use a declarative approach you must avoid imperative thinking.
My favourite iterate recursive example of a Fibonacci(10000) evaluation
might help you
Sequence{1..10000}->iterate(i : Integer; acc : Sequence(Integer) = Sequence{1,
1} | acc->including(acc->at(i) + acc->at(i+1)))->last()
Ed Willink
On 30/01/2012 13:24, Patricia Espada wrote:
> Hello
Re: Is it possible to modify condition collections of cycle? [message #786671 is a reply to message #786643] Mon, 30 January 2012 17:40 Go to previous messageGo to next message
Member
In that example you are simply modifying the acc variable. Forgetting the meaning of the Fibonacci evaluation, if we want to add something to the first sequence, how would we do it. For example:
Sequence{1..10000}->iterate(i : Integer; acc : Sequence(Integer) = Sequence{1,1} | if i = 10000 then <<Modify Sequence{1..10000} to Sequence{1..10000}>> else acc->including(acc->at(i) + acc->at(i+1)) endif)->last()
is there anyway to do that?!
Re: Is it possible to modify condition collections of cycle? [message #786678 is a reply to message #786671] Mon, 30 January 2012 17:55 Go to previous messageGo to next message
It is important to distinguish 'modify' which OCL cannot do, from
'create with a change from a reference'. iterate supports repetitive
creation of new accumulator values. [A smart OCL implementation may
recognize this creation-with-a-change to re-use and do a modify to a
stale variable, but this is an implementation detail that preserves the
OCL pure declarative behaviour.]
So replace <<Modify Sequence{1..10000} to Sequence{1..10000}>> by a new
Sequence construction such as <<Sequence{1..10000}->excluding(8888)>>.
Ed Willink
> endif)->last()
Re: Is it possible to modify condition collections of cycle? [message #786684 is a reply to message #786678] Mon, 30 January 2012 18:05 Go to previous messageGo to next message
Member
First of all, let me thank you Edward for your patience Smile
So in that case, even by excluding the number 8888, the iterate will contemplate that value?! There is now way, that the iterate will skip the number 8888?
This is possible in languages such as Java, and in my work if this was possible to do with OCL, it would be great. But I know that probably this question does not make sense in the OCL environment.
Re: Is it possible to modify condition collections of cycle? [message #786695 is a reply to message #786684] Mon, 30 January 2012 18:16 Go to previous messageGo to next message
HI
You have only expressed your real problem as a simplified solution, so I
have to guess at equivalent solutions that clearly you do not understand.
Try starting again by specifying your problem.
Ed Willink
On 30/01/2012 18:05, Patricia Espada wrote:
> First of all, let me thank you Edward for your patience :)
> the number 8888?
Re: Is it possible to modify condition collections of cycle? [message #786706 is a reply to message #786695] Mon, 30 January 2012 18:37 Go to previous messageGo to next message
Member
Ok, sorry, let me try again.
In EVL I can do something like this:
operation CLASS test(): Integer {
	var a := Set{1,2,3};
	var i := 0;
	while(a->notEmpty()) {
		i = i+1;
		if (a->last() = 2)
			a = a->excluding(a->last())->including(4);
		else
			a = a->excluding(a->last());
	return i;
and the result is 4, where I conclude that the set it's modified in the while. A operation like that one is something that i don't know how to put in the OCLInEcore, or if it's possible.
Re: Is it possible to modify condition collections of cycle? [message #786772 is a reply to message #786706] Mon, 30 January 2012 20:03 Go to previous messageGo to next message
I asked for specification of the problem; you have provided another
solution and described it as "test".
Ed Willink
> var i := 0;
> i = i+1;
> if (a->last() = 2)
> else
> return i;
> Thanks
Re: Is it possible to modify condition collections of cycle? [message #786787 is a reply to message #786772] Mon, 30 January 2012 20:20 Go to previous messageGo to next message
Member
Well, I'm clearly not making myself understand and I don't get what you are saying.
I simple wanted to now if it's possible in OCL to iterate a collection and while iterating modifying that same collection at the same time?! In my first post I've tried to explain that with an example, and again with the "test" operation.
Re: Is it possible to modify condition collections of cycle? [message #786821 is a reply to message #786787] Mon, 30 January 2012 21:06 Go to previous messageGo to next message
OCL is a specification language, and bas I wrote at the outset you
cannot modify the colledction, so the answer to your original problem is
that it's impossible.
But as so often the problem is wrongly expressed.
If you specify the problem that actually needs solving then there may be
a solution.
So perhaps you problem might be specified as;
Given a ? balanced tree of ?distinct values, determine the index in a
sorted set of those values at which a given testValue occurs.
If so, the solution might be
tree->closure(left->union(right)).value->sortedBy(n | n)->indexOf(testValue)
Ed Willink
> you are saying.
> Thanks
Re: Is it possible to modify condition collections of cycle? [message #786914 is a reply to message #786821] Tue, 31 January 2012 00:03 Go to previous messageGo to next message
Member
Hi again
Thank you once more Edward. I really didn't get that.
What got me into this question was that I want to determine a graph depth, knowing the root and that each node has ? number of childs.
I have a recursive solution, described here http://www.eclipse.org/forums/index.php/t/281497/, but it's not working. And I was wondering if it was possible to do these in a non-recursive way.
Kind regards
Re: Is it possible to modify condition collections of cycle? [message #787082 is a reply to message #786914] Tue, 31 January 2012 05:59 Go to previous messageGo to next message
On 31/01/2012 00:03, Patricia Espada wrote:
> Hi again
An ambiguous statement.
What is "that"? My 'explanation' or 'the need to specify the problem'.
> non-recursive way.
Again ambiguous. A restatement of your 'solution' or an explanation of
your thinking.
What response are you looking for?
Ed Willink
Re: Is it possible to modify condition collections of cycle? [message #787214 is a reply to message #787082] Tue, 31 January 2012 09:35 Go to previous message
Member
Edward Willink wrote on Tue, 31 January 2012 00:59
> Hi again
Not the explanation, what we wanted when you ask me to specify the problem. My problem was specified, was only the question that you already response, that it's impossible to modify a collection while iterating that same collection.
> non-recursive way.
your thinking.
Ed Willink
Then again, this was the motive for my first question. The only solution I have is a recursive one. I was hopping to find a non-recursive solution if my first question was possible. So, now i have to thing in another way to resolve the problem.
Thanks anyway for your help
Previous Topic:OCLInEcore recursive operations
Next Topic:Is it possible to retrieve the type name?
Current Time: Mon Feb 19 12:17:23 GMT 2018
Powered by FUDForum. Page generated in 0.02159 seconds
