Home » Eclipse Projects » BIRT » IGetParameterDefinitionTask getSelectionList get too time during evaluation(getSelectionList() is terrible slow )
icon4.gif  IGetParameterDefinitionTask getSelectionList get too time during evaluation [message #785270] Sat, 28 January 2012 19:11 Go to next message
Alessio Pollero is currently offline Alessio PolleroFriend
Member
I'm debugging my program that make use of the API to generate reports, and i noticed that when i call the method getSelectionList() of the IGetParameterDefinitionTask interface it is very slow, following some example :
Loaded new Selection list, loading time=17ms
Loaded new Selection list, loading time=960ms
Loaded new Selection list, loading time=3ms
Loaded new Selection list, loading time=1ms
Loaded new Selection list, loading time=240ms
Overall loading time=1422ms
as you can see the second parameter takes 960ms when the query associated with it get executed pretty fast :
7 rows in set (0.00 sec)
I have tried even removing the ORDER BY clause from the SQL query and move the sort to the parameter definition and the result is even worse :
Loaded new Selection list, loading time=14ms
Loaded new Selection list, loading time=1528ms
Loaded new Selection list, loading time=2ms
Loaded new Selection list, loading time=253ms
Overall loading time=1974ms
As you can see it gets 1,5 seconds to get the Selection List for a simple dynamic parameter linked with a dataset that execute a very lightweight SQL Query on a MySQL database that have only 7 rows as result set ...
Is there a way to improve performance ? How ?
Could be a bug of BIRT API ? I'm using version 3.7.1
Re: IGetParameterDefinitionTask getSelectionList get too time during evaluation [message #786625 is a reply to message #785270] Mon, 30 January 2012 16:45 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Is this a simple selection list or a cascaded parameter?
Jason
> http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.birt.doc.isv%2Fengine%2Fapi%2Forg%2Feclipse%2Fbirt%2Freport%2Fengine%2Fapi%2FIGetParameterDefinitionTask.html
> some example :
> result set ...
Re: IGetParameterDefinitionTask getSelectionList get too time during evaluation [message #786831 is a reply to message #786625] Mon, 30 January 2012 21:27 Go to previous messageGo to next message
Member
A Simple selection list .
Re: IGetParameterDefinitionTask getSelectionList get too time during evaluation [message #787455 is a reply to message #786831] Tue, 31 January 2012 15:45 Go to previous message
If you run the query separately does it take this long?
Jason
Previous Topic:Share one single rptlibrary for a tree of Reports
Next Topic:Using connection profiles with Weblogic
Current Time: Sun Apr 22 10:58:28 GMT 2018
Powered by FUDForum. Page generated in 0.02068 seconds
