Home » Newcomers » Newcomers » Install additinal plugins on milestone build(How to install additinal plugins (e.g. subversion) on a milestone build)
Install additinal plugins on milestone build [message #783748] Thu, 26 January 2012 11:28
Noam Missing name is currently offline Noam Missing nameFriend
I've recently downloaded 4.2M4. It is possiable to install any additinal plugins (e.g. SubClipse) on it? When I try Help --> Install new software I get:
Cannot complete the request. The installation has not been configured properly for Software Updates. See the error log for details.
The log shows:
!MESSAGE Could not locate the running profile instance. The eclipse.p2.data.area and eclipse.p2.profile properties may not be set correctly in this application's config.ini.
Any way arround this? I tried to enable classic updates or add additinal update sites in perferences with no luck.
Previous Topic:Debugging the applet
Next Topic:Ganymede fails to start, need to start from Square 1...
Current Time: Fri Feb 23 12:49:21 GMT 2018
Powered by FUDForum. Page generated in 0.02929 seconds
