Home » Newcomers » Newcomers » Selection does not contain a main type(Selection does not contain a main type)
Selection does not contain a main type [message #781730] Sun, 22 January 2012 04:40 Go to next message
Nathaniel Trujillo is currently offline Nathaniel TrujilloFriend
I typed this code the way it was in the tutorial I'm reading and it still tells me "selection does not contain a main type". Here is the code
public class Main2
	public static Boolean toBooleanObject(String str)
		if ("true".equalsIgnoreCase(str)) 	 { return Boolean.TRUE; }
		else if ("false".equalsIgnoreCase(str))  { return Boolean.FALSE; }
		else if ("on".equalsIgnoreCase(str))	 { return Boolean.TRUE; }
		else if ("off".equalsIgnoreCase(str))	 { return Boolean.FALSE; }
		else if ("yes".equalsIgnoreCase(str))	 { return Boolean.TRUE; }
		else if ("no".equalsIgnoreCase(str))	 { return Boolean.FALSE; }
		// no match
		return null;
Thanks for any help.
Re: Selection does not contain a main type [message #781905 is a reply to message #781730] Sun, 22 January 2012 17:32 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
> public class Main2
> // no match
> return null;
The code you have does not contain a main method. In order to run a
Java class, the class has to have a public static main method that takes
a String array as its argument.
If your class doesn't have the main method, Java won't run it.
Re: Selection does not contain a main type [message #781935 is a reply to message #781905] Sun, 22 January 2012 19:36 Go to previous messageGo to next message
Okay, that is odd. I tried putting public static void main(String[] args){...} in there but it gave me the same message "selection does not contain a main type". Can you show me exactly what my code is supposed to look like? This is the code I tried to run
public class Main2
			// no match
			return null;
Re: Selection does not contain a main type [message #781944 is a reply to message #781935] Sun, 22 January 2012 20:09 Go to previous messageGo to next message
For a bit more info, it wouldn't let me post the link but if you were to take a look at the tutorial I'm reading you would notice that many of the other examples do not have a main method. Is this tutorial just outdated? If so, could you tell me in general terms how to make my code up to date? I just need something general enough to apply to each program that I write even though it may not apply to all examples. More specifically, it would be nice to have some steps that I can take to turn the code in the tutorial into the most recent version of itself. If you would need the tutorial to answer these questions then I appologize. I'll just have to wait until I make more posts. Thanks.
Re: Selection does not contain a main type [message #781946 is a reply to message #781944] Sun, 22 January 2012 20:17 Go to previous message
Okay, it seems like I just had to make sure that the body of the main method came before the next method. When I did that, it ran with no errors.
Previous Topic:Getting code from SVN? Help
Next Topic:Need a Java Programmer
Current Time: Thu Jan 18 10:15:09 GMT 2018
Powered by FUDForum. Page generated in 0.02993 seconds
