Home » Eclipse Projects » Equinox » Access EJB in JBOSS from OSGI
Access EJB in JBOSS from OSGI [message #90239] Tue, 12 June 2007 07:47 Go to next message
Pedro Silva is currently offline Pedro SilvaFriend
I've several bundles running in OSGI inside JBoss AS. I want want to
access an EJB, that has been deployed in JBoss, from the code in bundles.
I did the necessary project dependencies in Eclipse in order to have
the reference to EJB in the OSGI bundle. The problem is that when I
invoke the bundle and it tries to find the EJB i get this error:
osgi>
16:57:21,461 ERROR [STDERR] java.lang.Error: Unresolved compilation
problems:
The import com.test cannot be resolved
FirstEJB3 cannot be resolved to a type
SO I'm thiking that the bundle does not have access to the packages in
the JBoss Classloader. I've already tried to change the launch.ini
settings like this:
osgi.contextClassLoaderParent = ccl in order to use the JBoss
classloader but I got the same error...
Any ideas?
Thanks in advance.
Pedro Silva
Re: Access EJB in JBOSS from OSGI [message #90611 is a reply to message #90239] Thu, 14 June 2007 00:39 Go to previous message
Simon Kaegi is currently offline Simon KaegiFriend
Hi Pedro,
You can get unresolved compilation problems when you export your bundle and
things didn't get built/resolved correctly.
There's usually an error log in a zip along-side where you built your
plugins - that might help you figure out what's going on.
Can you provide a few more details on what you're doing.
Are your running under the servletbridge or trying to start equinox
standalone. What version are you running... hopefully 3.3.?
-Simon
"Pedro Silva" <psilva@dcc.online.pt> wrote in message
news:f4lj4t$g0$1@build.eclipse.org...
> osgi>
> problems:
> settings like this:
> osgi.contextClassLoaderParent = ccl in order to use the JBoss classloader
> Any ideas?
> Thanks in advance.
> Pedro Silva
Previous Topic:Help find documentation - Export-Package: split
Next Topic:Testing bundles from the outside
Current Time: Mon Apr 23 21:25:59 GMT 2018
Powered by FUDForum. Page generated in 0.01821 seconds
