Home » Eclipse Projects » EclipseLink » DBWS: java.sql.SQLSyntaxErrorException(webservice returns SOAP Fault but does execute procedure )
DBWS: java.sql.SQLSyntaxErrorException [message #778991] Sat, 14 January 2012 10:27
Lonneke Dikmans is currently offline Lonneke DikmansFriend
Environment:
OEPE 11172 (toplink_11114)
WLS 10.1.3.5
Linux VB
Oracle XE database
HR Schema
I generated a webservice on the procedure ADD_JOB_HISTORY that is part of the hr schema that Oracle delivers with Oracle XE
PROCEDURE add_job_history
  (  p_emp_id          job_history.employee_id%type
   , p_start_date      job_history.start_date%type
   , p_end_date        job_history.end_date%type
   , p_job_id          job_history.job_id%type
   , p_department_id   job_history.department_id%type
IS
BEGIN
  INSERT INTO job_history (employee_id, start_date, end_date,
                           job_id, department_id)
    VALUES(p_emp_id, p_start_date, p_end_date, p_job_id, p_department_id);
END add_job_history;
I generated a webservice with the following builder file:
<dbws-builder xmlns:xsd="[link here, not allowed to post : ]">
 <properties>
..properties here
 </property>
 </properties>
  <procedure
    name="Jobhistory"
    catalogPattern="TOPLEVEL"
    procedurePattern="ADD_JOB_HISTORY"
    isSimpleXMLFormat="true"
</dbws-builder>
When I call this Webservice with SOAP UI
<[not allowed to post header]">
   <soapenv:Header/>
   <soapenv:Body>
      <hrs:Jobhistory>
         <hrs:P_EMP_ID>176</hrs:P_EMP_ID>
         <hrs:P_START_DATE>2013-02-02</hrs:P_START_DATE>
         <hrs:P_END_DATE>2014-02-02</hrs:P_END_DATE>
         <hrs:P_JOB_ID>SA_MAN</hrs:P_JOB_ID>
         <hrs:P_DEPARTMENT_ID>80</hrs:P_DEPARTMENT_ID>
      </hrs:Jobhistory>
   </soapenv:Body>
</soapenv:Envelope>
I get the following error:
[EL Warning]: 2012-01-14 11:01:11.478--DatabaseSessionImpl(14802092)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.1.3.v20110304-r9073): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLSyntaxErrorException: ORA-00900: invalid SQL statement
Error Code: 900
Call: BEGIN ADD_JOB_HISTORY(P_EMP_ID=>?, P_START_DATE=>?, P_END_DATE=>?, P_JOB_ID=>?, P_DEPARTMENT_ID=>?); END;
bind => [176.0, 2013-02-02 00:00:00.0, 2014-02-02 00:00:00.0, SA_MAN, 80.0]
Query: ValueReadQuery(name="Jobhistory" )
However, the row does get added to the database!
Does anybody have any clues?
regards Lonneke
Previous Topic:java.lang.NoSuchMethodError: javax.persistence.EntityManager.getCriteriaBuilder()Ljavax/persistence/
Next Topic:DBWS: java.sql.SQLSyntaxErrorException
Current Time: Tue Jun 19 19:54:14 GMT 2018
Powered by FUDForum. Page generated in 0.01479 seconds
