Home » Eclipse Projects » Remote Application Platform (RAP) » Problems using swt.virtual and a lazy content provider
Problems using swt.virtual and a lazy content provider [message #89683] Fri, 23 May 2008 14:09 Go to next message
Hugo Ferreira is currently offline Hugo FerreiraFriend
--------------010603040002060106010300
Hi all,
I'm trying to use SWT.VIRTUAL (and lazy loading) feature on a table but
i'm having some problems. I have drawn a SWT.VIRTUAL table with a lazy
content provider. The table is designed correctly and also the data
appears as it should. But when I close the view where this table is
designed I get a javascript error saying something like this:
"Could no evaluate javascript response: TypeError: w has no properties".
If I change the type of content provider (to a
IStructuredContentProvider) everything works ok and the view is closed
without any error.
I have seen some examples and snippets code but I couldn't manage to
solve the problem.
In attachment I send the view where I have a small example of the
implementation that generates the error. It is a very simple example.
Hope it helps.
Thanks in advance for any help.
Hugo Ferreira
Content-Type: text/java;
name="TableView.java"
Content-Disposition: inline;
filename="TableView.java"
package tiago.rap.workbench.views;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.jface.viewers.ILazyContentProvider;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
import org.eclipse.ui.part.ViewPart;
import tiago.rap.test.Person;
public class TableView extends ViewPart {
public static final String ID = "tiago.rap.test.tableview";
private List entityList;
public void createPartControl(Composite parent) {
parent.setLayout(new FillLayout());
entityList = new ArrayList<Person>();
entityList.add(new Person("A", 26, "Coimbra", "Portugal", "1982-03-19"));
entityList.add(new Person("B", 24, "Figueira Foz", "Portugal", "1984-08-20"));
entityList.add(new Person("C", 29, "Porto", "Portugal", "1978-04-09"));
entityList.add(new Person("D", 24, "Cascais", "Portugal", "1983-12-19"));
entityList.add(new Person("E", 25, "Viseu", "Portugal", "1983-10-10"));
entityList.add(new Person("F", 23, "Soure", "Portugal", "1984-09-13"));
entityList.add(new Person("G", 26, "Condeixa", "Portugal", "1982-05-13"));
entityList.add(new Person("H", 25, "Montemor-o-velho", "Portugal", "1983-12-25"));
entityList.add(new Person("I", 27, "Lisboa", "Portugal", "1981-11-30"));
entityList.add(new Person("J", 28, "Cantanhede", "Portugal", "1980-02-25"));
Table table = new Table(parent, SWT.NONE | SWT.VIRTUAL);
table.setLinesVisible(true);
table.setHeaderVisible(true);
final TableColumn nameTC = new TableColumn(table, SWT.CENTER);
nameTC.setText("Name");
nameTC.setWidth(100);
final TableColumn ageTC = new TableColumn(table, SWT.CENTER);
ageTC.setText("Age");
ageTC.setWidth(100);
final TableColumn cityTC = new TableColumn(table, SWT.CENTER);
cityTC.setText("City");
cityTC.setWidth(100);
final TableColumn countryTC = new TableColumn(table, SWT.CENTER);
countryTC.setText("Country");
countryTC.setWidth(100);
final TableColumn birthdateTC = new TableColumn(table, SWT.CENTER);
birthdateTC.setText("Birthdate");
birthdateTC.setWidth(100);
for (int i = 0; i < entityList.size(); i++) {
TableItem item = new TableItem(table, SWT.NONE);
Person p = (Person) entityList.get(i);
item.setText(0, p.getName());
item.setText(1, "" + p.getAge());
item.setText(2, p.getCity());
item.setText(3, p.getCountry());
item.setText(4, p.getBirthdate());
TableViewer viewer = new TableViewer(table);
if ((table.getStyle() & SWT.VIRTUAL) == SWT.VIRTUAL) {
viewer.setItemCount(entityList.size());
viewer.setContentProvider(new LazyContentProvider(entityList, viewer));
} else {
viewer.setContentProvider(getIStructuredContentProvider());
//viewer.setInput(entityList);
public void setFocus() {
// TODO Auto-generated method stub
private IStructuredContentProvider getIStructuredContentProvider() {
return (new IStructuredContentProvider() {
public void dispose() {
public void inputChanged(final Viewer v, final Object oldInput, final Object newInput) {
public Object[] getElements(final Object inputElement) {
return entityList.toArray();
class LazyContentProvider implements ILazyContentProvider {
private List<Object> list;
private TableViewer viewer;
public LazyContentProvider(final List<Object> entityList, TableViewer viewer) {
this.list = entityList;
this.viewer = viewer;
v.setInput(newInput);
public void updateElement(final int index) {
viewer.replace(list.get(index), index);
--------------010603040002060106010300--
Re: Problems using swt.virtual and a lazy content provider [message #89761 is a reply to message #89683] Sun, 25 May 2008 17:49 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hugo,
this seems to be a bug. You could open a bugzilla to track progress
on this issue.
Rüdiger
Hugo Ferreira wrote:
> Hi all,
> but i'm having some problems. I have drawn a SWT.VIRTUAL table with a
> lazy content provider. The table is designed correctly and also the data
> without any error.
> solve the problem.
> Hope it helps.
> Hugo Ferreira
Re: Problems using swt.virtual and a lazy content provider [message #90102 is a reply to message #89761] Mon, 26 May 2008 17:58 Go to previous messageGo to next message
I have investigated the problem a little more and I found that when the
view is closed the method
Object newInput)
from the lazy content provider is being called with the newInput object
null. Since it is null it will then generate an error that results in
the javascript error. For now I have added a small verification to see
if the object is null. Everything works with this small verification.
Nonetheless I have created a bugzilla entry with this id: 233998
Hugo Ferreira
Rüdiger Herrmann wrote:
> Hugo,
> this seems to be a bug. You could open a bugzilla to track progress on
> this issue.
> Cheers,
> Rüdiger
>> Hi all,
>> table but i'm having some problems. I have drawn a SWT.VIRTUAL table
>> with a lazy content provider. The table is designed correctly and also
>> the data appears as it should. But when I close the view where this
>> table is designed I get a javascript error saying something like this:
>> without any error.
>> solve the problem.
>> Hope it helps.
>> Hugo Ferreira
Re: Problems using swt.virtual and a lazy content provider [message #90162 is a reply to message #90102] Mon, 26 May 2008 22:47 Go to previous message
Hugo,
thanks for entering the bug. Please see my comment there.
Rüdiger
> Object newInput)
> Hugo Ferreira
>> Hugo,
>> this issue.
>> Cheers,
>> Rüdiger
>>> Hi all,
>>> also the data appears as it should. But when I close the view where
>>> this table is designed I get a javascript error saying something like
>>> this:
>>> closed without any error.
>>> solve the problem.
>>> Hope it helps.
>>> Hugo Ferreira
Previous Topic:Command Save / Save Action not working ???
Next Topic:Selected ViewPart Tab Color
Current Time: Sun May 20 21:38:03 GMT 2018
Powered by FUDForum. Page generated in 0.02348 seconds
