Home » Eclipse Projects » WindowBuilder » Odd Display of WindowBuilder (Ubuntu 11.10, Eclipse 4.2, Compiz)
Odd Display of WindowBuilder (Ubuntu 11.10, Eclipse 4.2, Compiz) [message #778344] Thu, 12 January 2012 13:39 Go to next message
Lars Vogel Unavailable until 15 August 2016 is currently offline Lars Vogel Unavailable until 15 August 2016Friend
I installed WindowBuilder in the latest integration build of Eclipse 4.2.
As I tried to open a SWT application in SWT Designer, Eclipse prompted me something about Compiz and if it can render it into a separate Window. Unfortunately I did not note done the exact text.
The palette of WindowBuilder is rendered strangely, see attached screenshot.
I currently don't know if the issue is created by the Compiz Window manager, Eclipse 4.2 or Ubuntu 11.10.
WindowBuilder runs fine in Eclipse 3.7 but here I also didn't get the Compiz popup.
Is there a way to turn this Compiz rendering off to check if that solves the issue?
Re: Odd Display of WindowBuilder (Ubuntu 11.10, Eclipse 4.2, Compiz) [message #778597 is a reply to message #778344] Fri, 13 January 2012 13:25 Go to previous messageGo to next message
Opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=368543 for the issue.
Re: Odd Display of WindowBuilder (Ubuntu 11.10, Eclipse 4.2, Compiz) [message #779077 is a reply to message #778597] Sat, 14 January 2012 16:26 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric ClaybergFriend
Thanks. Looks like it has been confirmed as an SWT issue.
Re: Odd Display of WindowBuilder (Ubuntu 11.10, Eclipse 4.2, Compiz) [message #779131 is a reply to message #779077] Sat, 14 January 2012 20:19 Go to previous message
Yes. Workaround is available:
If you add the following line to the end of the
eclipse.ini file before launching 4.2, things will draw properly:
-Dorg.eclipse.swt.internal.gtk.useCairo=false
Previous Topic:IllegalStateException: no hide stop and hide start
Next Topic:Error when using addComponentListener in a getter
Current Time: Sat Apr 21 02:12:31 GMT 2018
Powered by FUDForum. Page generated in 0.01992 seconds
