Home » Modeling » Papyrus » Programmatically configure visible palette for diagram((from a private email exchange))
Programmatically configure visible palette for diagram [message #777312] Tue, 10 January 2012 09:14 Go to next message
Remi Schnekenburger is currently offline Remi SchnekenburgerFriend
We would like to programmatically enable and disable the palette configurations for a certain diagram. For example:
In UTP you can apply <<testcase>> to any behavior. We pre-configured a palette for sequences/activities/state machines. Only those elements, which are sensible, respectively supported in our methodology are provided in that palettes. Now, if the user wants to create a <<testcase>> sequence diagram, we simply reuse the CreateSequenceDiagramCommand, but want to programmatically disable the default sequence palette and enable the customized palette. I browsed the source, unfortunately with no success.
Can you point me to the code section, where the UI invoked the de-/activation of palette configurations?
Thanks a lot.
Marc-Florian
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: Programmatically configure visible palette for diagram [message #777315 is a reply to message #777312] Tue, 10 January 2012 09:15 Go to previous message
Hi Marc-Florian,
To programmatically show/hide a palette, you can use the static method org.eclipse.papyrus.diagram.common.part.PapyrusPalettePreferences.changePaletteVisibility(String, String, boolean).
The class is located in the plugin "org.eclipse.papyrus.diagram.common".
An example of the usage of this method is located in the class: org.eclipse.papyrus.diagram.common.palette.customization.dialog.PapyrusPaletteCustomizerDialog.
This dialog is used to customize the content of the palettes, and which palette should be visible/hidden. It is located in the plugin "org.eclipse.papyrus.diagram.common.palette.customization".
Do you agree to copy/paste this discussion in Papyrus forum? We prefer to answer technical questions in the forum, this let the other users discover the solution to their problems.
RĂ©mi
Remi Schnekenburger
Previous Topic:SysML 1.2 supported by Papyrus?
Next Topic:What is the current status of this OCL in profiles issue?
Current Time: Tue May 22 02:44:39 GMT 2018
Powered by FUDForum. Page generated in 0.01479 seconds
