Home » Eclipse Projects » GEF » Undo/Redo key bindings
Undo/Redo key bindings [message #777040] Mon, 09 January 2012 17:54 Go to next message
Jan Krakora is currently offline Jan KrakoraFriend
Hi guys,
I have implemented a GEF based editor. My problem is with Undo and Redo actions keybindings.
The code in my editor
protected void createActions() {
	ActionRegistry registry = getActionRegistry();
	IAction action;
	action = new UndoAction(this);
	registry.registerAction(action);
	getStackActions().add(action.getId());
	action = new RedoAction(this);
and in my ActionBarContributor
protected void buildActions() {
	addRetargetAction(new UndoRetargetAction();
	addRetargetAction(new RedoRetargetAction());
public void contributeToMenu(IMenuManager menubar) {
	super.contributeToMenu(menubar);
	IMenuManager editMenu = menubar.findMenuUsingPath("edit");
	if (editMenu != null) {
		editMenu.insertBefore(IWorkbenchActionConstants.MB_ADDITIONS, getAction(ActionFactory.UNDO.getId()));
		editMenu.insertBefore(IWorkbenchActionConstants.MB_ADDITIONS, getAction(ActionFactory.REDO.getId()));
Undo/Redo works fine except there is no key bindings for them. My code is same as in Logic example and when I run it, keybindigs work there.
Any ideas?
[Updated on: Mon, 09 January 2012 18:01]
Report message to a moderator
Re: Undo/Redo key bindings [message #777043 is a reply to message #777040] Mon, 09 January 2012 18:00 Go to previous messageGo to next message
When I put this code to my ActionBarAdvisor
protected void makeActions(final IWorkbenchWindow window) {
	register(ActionFactory.UNDO.create(window));
	register(ActionFactory.REDO.create(window));
and edit editor's ActionBarContributor
	addRetargetAction(new UndoRetargetAction() {
		public String getActionDefinitionId() {
			return ActionFactory.UNDO.getCommandId();
	addRetargetAction(new RedoRetargetAction() {
			return ActionFactory.REDO.getCommandId();
it works fine, but I don't think that it's the right solution.
It should work just with addRetargetAction(new UndoRetargetAction());
Re: Undo/Redo key bindings [message #777136 is a reply to message #777043] Mon, 09 January 2012 23:13 Go to previous messageGo to next message
Arieh Bibliowicz is currently offline Arieh BibliowiczFriend
Does your editor extend
GraphicalEditor
? if so, why not call
super.createActions()
to enable the undo, instead of repeating the same code that already exists in
GraphicalEditor
? I say this because this is what I do in my editor and things are working just fine. Its worth a try Smile
Re: Undo/Redo key bindings [message #777352 is a reply to message #777136] Tue, 10 January 2012 10:16 Go to previous message
Hi Arieh,
yes, my editor extends GraphicalEditor and I don't override makeActions().
I just copied content of the GraphicalEditor's makeActions() method here to mention that Undo/Redo are properly registered.
Well as I said, Undo/Redo works, but theirs keybindings doesn't Sad
Previous Topic:Connection decoration options
Next Topic:GEF functionality within other editor window
Current Time: Wed Jun 20 13:45:29 GMT 2018
Powered by FUDForum. Page generated in 0.01499 seconds
