Home » Eclipse Projects » Equinox » Problems with equinox console in 4.2M4
Problems with equinox console in 4.2M4 [message #776066] Sat, 07 January 2012 10:46 Go to next message
Cristiano Gaviao is currently offline Cristiano GaviaoFriend
I'm trying to use my equinox application with 4.2M4 but I can't use my console commands.
When I call help, I can see this:
osgi> help
equinox:jbStatus
equinox:jbRunStoriesWithAnnotatedEmbedder
equinox:confapply
equinox:comp
equinox:component
The compatibility component add my command at equinox group.
When I try to call it I receive this error:
osgi> equinox:jbRunStoriesWithAnnotatedEmbedder TraderAnnotatedEmbedder
gogo: IllegalArgumentException: Cannot find the command method for: _jbrunstorieswithannotatedembedder
osgi> jbRunStoriesWithAnnotatedEmbedder TraderAnnotatedEmbedder
can someone tell me what I need to do to make my commands to work with juno ?
thanks and regards
ps: I did the same question here, but Tom suggested me to ask here at Equinox Forum.
Re: Problems with equinox console in 4.2M4 [message #777008 is a reply to message #776066] Mon, 09 January 2012 16:34 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You need to at least add the org.apache.felix.gogo.* bundles to your application to get full access to the console. In my default Eclipse SDK 4.2 M4 I have:
org.apache.felix.gogo.command_0.8.0.v201108120515.jar
org.apache.felix.gogo.runtime_0.8.0.v201108120515.jar
org.apache.felix.gogo.shell_0.8.0.v201110170705.jar
Then maybe there's a new equinox console command contribution?
PW
Re: Problems with equinox console in 4.2M4 [message #777031 is a reply to message #777008] Mon, 09 January 2012 17:26 Go to previous messageGo to next message
Hi Paul,
I already add those new dependencies.
Before have added them I couldn't start the console...
I can see all gogo commands... but my problem, as I tried to describe before, is that I can't use my old command bundle.
My old command doesn't have the group... now when I type help, I see them:
equinox:jbStatus
But I can't use it...
So I can't use my equinox app at 4.2M4.
I'm looking for an example that help me to convert my command bundle to the new one, so I can test my equinox application with Juno.
cheers
Cristiano
Re: Problems with equinox console in 4.2M4 [message #805507 is a reply to message #777031] Thu, 23 February 2012 21:09 Go to previous messageGo to next message
miguel angel is currently offline miguel angelFriend
I have the same problem, all the commands that contains uppercase characters doesn't work with the new console.
This problem also affects to the commands of declarative services.
Re: Problems with equinox console in 4.2M4 [message #806944 is a reply to message #776066] Sat, 25 February 2012 19:09 Go to previous messageGo to next message
Gunnar Wagenknecht is currently offline Gunnar WagenknechtFriend
Am 07.01.2012 11:46, schrieb Cristiano avi:
Can you please open a bug against Equinox? The new console should still
support all the existing commands. It looks like you found a bug
regarding case-sensivity.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Problems with equinox console in 4.2M4 [message #856738 is a reply to message #806944] Wed, 25 April 2012 23:58 Go to previous messageGo to next message
Sebastien Angers is currently offline Sebastien AngersFriend
See Bug 377708 + proposed patch.
Sebastien
Re: Problems with equinox console in 4.2M4 [message #894767 is a reply to message #776066] Tue, 10 July 2012 12:52 Go to previous message
Kees Pieters is currently offline Kees PietersFriend
I've had the same problem running equinox 3.8 as target with a JUNO IDE. It was fixed by including the felix gogo plugins in the debug configuration (see http://www.eclipse.org/equinox/incubator/console/design-doc.php) and then adding the VM arguments:
-Dosgi.console.enable.builtin=true
apparently you have to activate the old-fashioned commands, instead that they are deactivated by the VM argument
Previous Topic:Prevent Bundle from being loaded
Next Topic:Issue with Non OSGi eclipse bundles
Current Time: Mon Apr 23 13:40:12 GMT 2018
Powered by FUDForum. Page generated in 0.02372 seconds
