Home » Eclipse Projects » Remote Application Platform (RAP) » ActionSet visibility
ActionSet visibility [message #88978] Wed, 21 May 2008 05:12 Go to next message
Setya Nugdjaja is currently offline Setya NugdjajaFriend
We have the following code :
In plugin.xml:
<extension id="com.farbeyond.input.ui.actionSet"
point="org.eclipse.ui.actionSets">
<actionSet id="2.Edit" label="Edit" visible="false">
<action id="menu.edit.new.id" icon="images/new.gif" label="New"
retarget="true"
disabledIcon="images/new_disabled.gif"
toolbarPath="additions/slot.edit/Group1"
tooltip="New"/>
</actionSet>
</extension>
In my ActionBarAdvisor:
protected void fillCoolBar(ICoolBarManager coolbarManager)
coolbarManager.add(new
GroupMarker(IWorkbenchActionConstants.MB_ADDITIONS));
coolbarManager.appendToGroup(IWorkbenchActionConstants.MB_AD DITIONS,new
GroupMarker("slot.edit"));
In my IEditorPart:
public void init(IEditorSite site, IEditorInput input) throws
PartInitException
setSite(site);
setInput(input);
IAction action = new Action()
public void run()
System.out.println("new");
site.getActionBars().setGlobalActionHandler("menu.edit.new.id ", action);
The above code is to display certain ActionSet when we open an
IEditorPart, it used to work in our old RCP application, but not anymore
(even in RCP).
Right now we have to set the 'visible' attribute in plugin.xml to 'true'
to see the ActionSet, but this makes the ActionSet visible even if there's
no IEditorPart open.
The only workaround I can think of is attaching a IPartListener in the
IEditorPart and calling IWorkbenchPage.showActionSet/hideActionSet on
partActivated/partDeactivated callbacks, but this doesn't seem right to me
since ActionSet visibility should be taken care by the workbench.
Any help would be greatly appreciated.
Best Regards,
Setya
Re: ActionSet visibility [message #89617 is a reply to message #88978] Fri, 23 May 2008 12:48 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
you can use EditorActionBarContributor to show/hide menu- and tool-items
if a editor is activated/deactivated.
Ciao
Frank
-----Urspr√ľngliche Nachricht-----
Von: Setya [mailto:jsetya@gmail.com]
Bereitgestellt: Mittwoch, 21. Mai 2008 07:12
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: ActionSet visibility
Betreff: ActionSet visibility
In plugin.xml:
<actionSet id="2.Edit" label="Edit" visible="false"> <action
retarget="true"
tooltip="New"/>
</actionSet>
</extension>
protected void fillCoolBar(ICoolBarManager coolbarManager) {
In my IEditorPart:
PartInitException {
setSite(site);
setInput(input);
public void run()
action); } ..
(even in RCP).
there's no IEditorPart open.
me since ActionSet visibility should be taken care by the workbench.
Best Regards,
Setya
Re: ActionSet visibility [message #89654 is a reply to message #89617] Fri, 23 May 2008 13:42 Go to previous message
Frank,
Thanks for your suggestion above.
I've tried with EditorActionBarContributor but it didn't work either. The
strange thing is the code I posted earlier used to work in RCP. I only
have to call site.getActionBars().setGlobalActionHandler to make them
visible.
Setya
Previous Topic:BUG: Tree row hight on font change
Next Topic:IFile
Current Time: Fri Feb 23 06:43:34 GMT 2018
Powered by FUDForum. Page generated in 0.01594 seconds
