Home » Eclipse Projects » EclipseLink » getId of metaModel will NEVER work for embededID(possible major bug...)
icon5.gif  getId of metaModel will NEVER work for embededID [message #770827] Sun, 25 December 2011 08:35 Go to next message
elhanan Maayan is currently offline elhanan Maayan
hi..
i tried posting this in bugzilla but something is wrong anyway here's the code in getId of IdentifybleTypeImpl:
 for(SingularAttribute<? super X, ?> anAttribute : idAttributes) {
                // Verify type is correct - relax restriction on null and Object.class (from same classLoader)
                if(null == type || Object.class == type ||
                        ((type != null) && (type.getCanonicalName().equals(anAttribute.getJavaType().getCanonicalName())))) {
                    idAttribute = (SingularAttribute<? super X, Y>) anAttribute;
                } else {
                    throw new IllegalArgumentException(ExceptionLocalization.buildMessage(
                        "metamodel_identifiable_id_attribute_type_incorrect",
                        new Object[] { anAttribute, this, type, anAttribute.getJavaType() }));
problem is that in case of embdebleid this will ALWAYS fall on IAE cause no matter what, the set if idAttributes is different.
so either type is equal to the first or second, but if it equels to the first then the second comparison (or the one after that) will break it..
Re: getId of metaModel will NEVER work for embededID [message #777522 is a reply to message #770827] Tue, 10 January 2012 11:13 Go to previous message
James Sutherland is currently offline James Sutherland
Please log a bug and include your model and exception stack trace.
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
James : Wiki : Book : Blog : Twitter
Previous Topic:Weving
Next Topic:getId of metaModel will NEVER work for embededID
Current Time: Tue Jun 18 22:13:05 EDT 2013
Powered by FUDForum. Page generated in 0.01602 seconds
