Home » Eclipse Projects » GEF » Re: CVS Graph plugin for Eclipse available
Re: CVS Graph plugin for Eclipse available [message #87403] Tue, 15 July 2003 21:13 Go to next message
Jimisola Laursen is currently offline Jimisola LaursenFriend
Is it possible to get CVS Graph to work with the latest integration version of
Eclipse?
I've tried with GEF 2.1 and 2.1.1 without any luck.
I have used it under M1 and I really love the plugin.
Keep up the good work!
Jimisola
Re: CVS Graph plugin for Eclipse available [message #87417 is a reply to message #87403] Tue, 15 July 2003 21:40 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Could somebody break this train of messages so that it doesn't keep
duplicating on three different newsgroups? It should probably be
continued only on the gef newsgroup.
Thanks, Rich Kulp
Re: CVS Graph plugin for Eclipse available [message #87462 is a reply to message #87403] Tue, 15 July 2003 22:42 Go to previous message
Jeffrey Bonevich is currently offline Jeffrey BonevichFriend
Member
I have tried with Version 2.1.1, Build Id: 200306271545 of Eclipse and
GEF 2.1.0 on my RH 7.1 Linux machine (motif) without problems. Anything
peculiar about your install? Are you using the GEF SDK or just the
runtime plugin? I run with the full SDK. Might be something I need to
look into here if you confirm that it is the runtime only.
jeff
> Eclipse?
> Jimisola
Jeffrey Bonevich
Ann Arbor, Michigan
bonevich at covad dot net
jeff at bonevich dot com
http://www.bonevich.com
"Make me a fire and I'm warm for a night. Set me
on fire and I'm warm for the rest of my life."
- Ancient Didactical Saying
Previous Topic:why no tool change notification in EditDomain
Next Topic:Creating connections
Current Time: Mon Jun 18 23:28:19 GMT 2018
Powered by FUDForum. Page generated in 0.02151 seconds
