Home » Eclipse Projects » Nebula » Binding Long-Values in FormattedText (DateTimeFormatter)
Binding Long-Values in FormattedText (DateTimeFormatter) [message #769613] Thu, 22 December 2011 12:14 Go to next message
Marcel  is currently offline Marcel Friend
Hi @ all,
I need your help in binding a FormattedText.
From the database I get Long values. These values must be brought in the format "HH: mm".
Here is a little bit code:
The FormattedText
        FormattedText worktimeText = new FormattedText(client);
        worktimeText.setFormatter(new DateTimeFormatter("HH:mm"));
        gd = new GridData();
        gd.horizontalSpan = 2;
        worktimeText.getControl().setLayoutData(gd);
        GridDataFactory.swtDefaults().hint(30, SWT.DEFAULT).applyTo(worktimeText.getControl());
        bindWorktimeText(worktimeText.getControl(), editor);
The Binding
    private void bindWorktimeText(Text worktimeText, StandbyTypeEditor editor) {
        IObservableValue worktimeWidget = WidgetProperties.text(SWT.Modify).observe(worktimeText);
        IObservableValue worktimeModel = PojoProperties
            .value(StandbyTypeVO.WORK_TIME_FIELD).observe(editor.getModel());
        UpdateValueStrategy worktimeToTarget = new UpdateValueStrategy();
        worktimeToTarget.setConverter(new IConverter() {
            public Object getToType() {
                return Date.class;
            public Object getFromType() {
                return Long.class;
            public Object convert(Object fromObject) {
                  Date date = new Date((Long) fromObject);
                  return date;
        editor.getBindingContext().bindValue(worktimeWidget, worktimeModel, null, worktimeToTarget);
Without the ValueStrategy-Converter the text is blank but i get an exception when i try to convert it.
org.eclipse.core.databinding.BindingException: converter does not convert to type class java.lang.String Expected: class java.sql.Date, actual: class java.lang.String
can someone help me?
Greetings
[Updated on: Thu, 22 December 2011 13:28]
Report message to a moderator
Re: Binding Long-Values in FormattedText (DateTimeFormatter) [message #780444 is a reply to message #769613] Tue, 17 January 2012 22:52 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Hi Marcel,
what do you expect is wrong? Do you think the widget is not playing along with the databinding framework?
Please file a bug if this is the case.
Wim
Re: Binding Long-Values in FormattedText (DateTimeFormatter) [message #809522 is a reply to message #780444] Wed, 29 February 2012 00:41 Go to previous message
On second view:
Binds to a String. Your converter expects a long.
Previous Topic:TableCombo Fix for Windows 7
Next Topic:How traverse on composite Nebula widget DateChooserCombo
Current Time: Thu May 24 00:47:01 GMT 2018
Powered by FUDForum. Page generated in 0.02221 seconds
