Home » Eclipse Projects » BIRT » BIRT Report Designer And JDBC Drivers(Test Connection)
BIRT Report Designer And JDBC Drivers [message #768870] Wed, 21 December 2011 00:34 Go to next message
Don Rogers is currently offline Don RogersFriend
I use BIRT Report Designer 3.7.1. All of my connection configurations were correct, and using JDBC v2.0 Driver, until I recently installed the 6 Update 29 JRE Patch. It now appears that I should use the JDBC v3.0 Driver, but I'm unable to get my Test Connection to work. Any suggestions? Here are the screen shots:
index.php/fa/6510/0/
index.php/fa/6511/0/
index.php/fa/6512/0/
index.php/fa/6513/0/
  • Attachment: BIRT_1.GIF
    (Size: 105.21KB, Downloaded 430 times)
  • Attachment: BIRT_2.GIF
    (Size: 50.47KB, Downloaded 391 times)
  • Attachment: BIRT_3.GIF
    (Size: 49.66KB, Downloaded 382 times)
  • Attachment: BIRT_4.GIF
    (Size: 116.25KB, Downloaded 398 times)
Re: BIRT Report Designer And JDBC Drivers [message #768875 is a reply to message #768870] Wed, 21 December 2011 00:47 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Don
As a test could you remove sqljdbc.jar and leave sqljdbc4.jar and then
restart Eclipse?
Jason
Previous Topic:Cross-tab issues
Next Topic:chart interactivity with dynamic parameter from source
Current Time: Wed Jun 20 23:15:35 GMT 2018
Powered by FUDForum. Page generated in 0.02014 seconds
