Home » Eclipse Projects » XML Schema Definition (XSD) » Being introduced to XSDs(I am struggling at the first hurdle!)
Being introduced to XSDs [message #768136] Mon, 19 December 2011 16:31 Go to next message
d.shillcock is currently offline d.shillcockFriend
Hello everyone,
I am currently writing a document from XML and transforming it into a website. I have thus far been using a DTD to validate the document however that is reaching the limits of what I require. I am using XMLPad to write my XML/XSLT/DTD/XSD. Could someone point me in the right direction as to why this example code is not working?
Note: I've replaced the url with the word 'link' due to posting limits.
<?xml version="1.0"?>
<document xmlns:xsi="link.w3.org/2001/XMLSchema-instance"
          xsi:noNamespaceSchemaLocation="documentation.xsd">
          <data>
            <authors>
              <author>
                <name>Daniel Shillcock</name>
                <email>d.shillcock@email.com</email>
              </author>
            </authors>
          </data>
</document>
I would like a choice between authors and content elements. I have tried to implement this with the following XSD, however it is not producing the results I expect.
<xs:schema xmlns:xs="link.w3.org/2001/XMLSchema">
  <xs:element name="document">
    <xs:complexType>
      <xs:sequence>
        <xs:element name="data" type="xs:anyType">
          <xs:complexType>
            <xs:choice>
              <xs:sequence>
                <xs:element name="authors" type="xs:anyType"/>
                  <xs:sequence>
                    <xs:element name="name" type="xs:string"/>
                    <xs:element name="email" type="xs:string"/>
                  </xs:sequence>
                </xs:sequence>
              <xs:element name="content" type="xs:anyType"/>
            </xs:choice>
          </xs:complexType>
        </xs:element>
      </xs:sequence>
    </xs:complexType>
  </xs:element>
</xs:schema>
I can't imagine how bad this looks to a trained eye. Any help is greatly appreciated!
[Updated on: Mon, 19 December 2011 16:36]
Report message to a moderator
Re: Being introduced to XSDs [message #768153 is a reply to message #768136] Mon, 19 December 2011 16:57 Go to previous message
Comments below.
On 19/12/2011 5:32 PM, d.shillcock wrote:
> Hello everyone,
> <data>
> <authors>
> <author>
> </author>
> </authors>
> </data>
> </document>
> <xs:complexType>
> <xs:sequence>
You can't have both a type attribute and an anonymous type, i.e., an
element can have only one type. Have you validated the XSD itself?
> <xs:complexType>
> <xs:choice>
> <xs:sequence>
> <xs:element name="auhors" type="xs:anyType"/>
Again a problem with there being more than one type for this element.
Clearly a type in your element name as well. And there's no nested
"author" element to be seen either.
> <xs:sequence>
> </xs:sequence>
> </xs:sequence>
> </xs:choice>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
Note that this newsgroup is for asking questions about the XSD model's
API, not general, I need help with designing XML Schemas. It doesn't
look like you've even used XSD to validate your schema, so that would be
a good start to ensure you have something sensible before you start
wondering why your instances aren't validated properly.
Previous Topic:Serialize XSD Object
Next Topic:xpath error
Current Time: Tue Apr 24 05:10:46 GMT 2018
Powered by FUDForum. Page generated in 0.02119 seconds
