Home » Language IDEs » ServerTools (WTP) » integrate WSDLEditor(org.eclipse.wst.wsdl.ui) into a rcp project.
icon5.gif  integrate WSDLEditor(org.eclipse.wst.wsdl.ui) into a rcp project. [message #767891] Mon, 19 December 2011 06:44 Go to next message
logian  is currently offline logian Friend
I have a rcp project. I add dependency of org.eclipse.wst.wsdl.ui(1.2.403).
I open a wsdl editor using java code as
"workbenchPage.openEditor(fileEditorinput, WSDLEditorPlugin.WSDL_EDITOR_ID);".
The problem is:
1,The first time I open a wsdl editor ,it cannot be opened. the error is "Could not open the editor: Group not found: additions" on an ErrorEditorPart.
2,I close the error editor. Then I open it again. This time it could be opened.
But something is still wrong. The Protocol property of Port is null however SOAP and HTTP should be there.
Any help is grateful. Thanks.
I uploaded my test rcp project.
Error message is as follow:
!ENTRY org.eclipse.ui 4 0 2011-12-19 14:21:20.147
!MESSAGE An unexpected exception was thrown.
!STACK 0
at org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.deactivateContext(ASDMultiPageEditor.java:364)
at org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.dispose(ASDMultiPageEditor.java:349)
at org.eclipse.wst.wsdl.ui.internal.InternalWSDLMultiPageEditor.dispose(InternalWSDLMultiPageEditor.java:431)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:705)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at testsss.MyAction.run(ApplicationActionBarAdvisor.java:70)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at testsss.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
!MESSAGE Unable to create editor ID org.eclipse.wst.wsdl.ui.internal.WSDLEditor: Group not found: additions
!STACK 0
java.lang.IllegalArgumentException: Group not found: additions
at org.eclipse.jface.action.ContributionManager.addToGroup(ContributionManager.java:131)
at org.eclipse.jface.action.ContributionManager.appendToGroup(ContributionManager.java:145)
at org.eclipse.jface.action.SubContributionManager.appendToGroup(SubContributionManager.java:82)
at org.eclipse.wst.wsdl.ui.internal.WSDLActionBarContributor.contributeToMenu(WSDLActionBarContributor.java:246)
at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:167)
at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:146)
at org.eclipse.wst.wsdl.ui.internal.WSDLActionBarContributor.init(WSDLActionBarContributor.java:222)
at org.eclipse.ui.internal.EditorManager.createEditorActionBars(EditorManager.java:341)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:820)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
  • Attachment: testsss.rar
    (Size: 58.60KB, Downloaded 174 times)
Re: integrate WSDLEditor(org.eclipse.wst.wsdl.ui) into a rcp project. [message #768407 is a reply to message #767891] Tue, 20 December 2011 04:36 Go to previous message
I fixed the second problem. I added plugin dependency of "org.eclipse.core.runtime.compatibility;bundle-version="3.2.100"", then soap and http appeared.
I traced the source code of org.eclipse.wst.wsdl.ui.*.
The error arises here.
______________
org.eclipse.wst.wsdl.ui.internal.WSDLEditorPlugin.ContentGeneratorUIExtensionRegistryReader.readElement();
protected void readElement(IConfigurationElement element)
if (element.getName().equals(ELEMENT_CONTENT_GENERATOR))
String name = element.getAttribute(ATT_NAME);
String namespace = element.getAttribute(ATT_NAMESPACE);
if (name != null && namespace != null)
ContentGeneratorUIExtension bindingGeneratorExtension = new ContentGeneratorUIExtension(name, namespace);
bindingGeneratorExtension.setPortOptionsPageClassName(element.getAttribute(ATT_PORT_OPTIONS_PAGE_CLASS));
bindingGeneratorExtension.setBindingOptionsPageClassName(element.getAttribute(ATT_BINDING_OPTIONS_PAGE_CLASS));
bindingGeneratorExtension.setLabel(element.getAttribute(ATT_LABEL));
try
ClassLoader pluginClasssLoader = element.getDeclaringExtension().getDeclaringPluginDescriptor().getPlugin().getClass().getClassLoader();// Error arises here. getDeclaringPluginDescriptor() is not supported if you have not added dependendy of org.eclipse.core.runtime.compatibility.
bindingGeneratorExtension.setClassLoader(pluginClasssLoader);
registry.add(bindingGeneratorExtension);
catch (Exception e)
{//Here, I think the exception should be printed. Other wise, it's very hard to find out the problem.
Line 563
IExtension.getDeclaringPluginDescriptor()
Deprecated. IPluginDescriptor is not part of the new runtime and its function has been split over several parts of the new runtime. This method is not available (returns null) if the compatibility layer is not installed. Use getNamespace() to get the symbolic id of the declaring plug-in. See IPluginDescriptor to see how to update your use-cases.
______________________
Sorry for the mess of my words. But hope that I could help someone:)
[Updated on: Tue, 20 December 2011 04:36]
Report message to a moderator
Previous Topic:Java EE perspective not available
Next Topic:access include path from inferrence provider?
Current Time: Sat May 26 17:47:29 GMT 2018
Powered by FUDForum. Page generated in 0.01362 seconds
