Home » Eclipse Projects » GEF » programmatically opening GraphicalEditor
programmatically opening GraphicalEditor [message #86798] Fri, 11 July 2003 14:33 Go to next message
Hong Deng is currently offline Hong DengFriend
Hi All,
I want to open my GraphicalEditor programmatically as a result of a menu
selection by the user. The problem I have is what input should I give to
openEditor() method of IWorkbenchPage. I've tried many things, but I
always get a NullPointerException.
Bharat
Re: programmatically opening GraphicalEditor [message #86840 is a reply to message #86798] Fri, 11 July 2003 19:40 Go to previous message
Originally posted by: g.wagenknecht.intershop.com
"Qhmd" <hmdeng6@yahoo.com> wrote in message
news:3F0ECAB4.7F5119D8@yahoo.com...
You should probably use the same IEditorInput you use when it is opened
regulary. Also don't forget the editor id. A good point to look at is the
EditorUtility class available in JDT UI source.
Cu, Gunnar
Previous Topic:PaletteViewer & FigureCanvas
Next Topic:Re: Drag and Drop
Current Time: Thu Jun 21 10:52:45 GMT 2018
Powered by FUDForum. Page generated in 0.01400 seconds
