How to install framework extension? [message #761995] |
Wed, 07 December 2011 12:01 |
Anastasia Drozhzha Messages: 2 Registered: December 2011 |
Junior Member |
I have a custom framework extension(let it be test.framework.extension). I wanna make it available via a feature installation. I added a p2.inf to a META-INF directory of the framework extenstion fragment, created a feature containing this fragment only, created an update site for this feature.
p2.inf contains:
instructions.configure = \
setProgramProperty(propName:testValue1,propValue:testValue2);
As far as I understand this property should be added to config.ini file.
(of course, not testValue1 but osgi.framework.extensions should be used but it does not matter for now)
I install my fragment through UI (Help->Install New Software->select local site) but I do not see any changes in eclipse/configuration/config.ini
Am I doing something wrong? Eclipse version is 3.7.
[Updated on: Fri, 09 December 2011 09:27] Report message to a moderator
FUDForum. Page generated in 0.03264 seconds
