Home » Eclipse Projects » Eclipse Communications Framework (ECF) » Learning Tutorial(From where can I learn Eclipse Workbench Collaboration using ECF)
Learning Tutorial [message #760366] Fri, 02 December 2011 07:57 Go to next message
UmaShankar Subramani is currently offline UmaShankar SubramaniFriend
I have project to work with Shared Editors. I need to use ECF. But I dont get any tutorial for ECF, as far as I googled.
Could any one please tell me whether there is a book foe learning ECF or any tutorials to learn Eclipse Workbench Collaboration from the beginning.
[Updated on: Mon, 05 December 2011 15:32]
Report message to a moderator
Re: Learning Tutorial [message #760571 is a reply to message #760366] Sat, 03 December 2011 02:08 Go to previous messageGo to next message
Markus Kuppe is currently offline Markus KuppeFriend
> any tutorials to learn from the beginning
http://wiki.eclipse.org/ECF#ECF_Documentation_Project
Markus
Re: Learning Tutorial [message #760728 is a reply to message #760571] Sun, 04 December 2011 21:36 Go to previous messageGo to next message
Dear Markus,
Thanks a lot!!! I have started reading the documentation of ECF. But I need some code samples to learn how a simple ECF project works.
Could you please tell me where can I get some code samples(not Java Doc) for a simple ECF project.
Re: Learning Tutorial [message #760730 is a reply to message #760728] Sun, 04 December 2011 21:43 Go to previous messageGo to next message
I am doing my thesis on "Concurrent modelling in eclipse". It is shared editing of models in eclipse.
I see that, until now there are only shared editing for text editors. Is not the shared editing for
models implemented using ECF?
[Updated on: Sun, 04 December 2011 21:43]
Re: Learning Tutorial [message #761051 is a reply to message #760730] Mon, 05 December 2011 20:18 Go to previous messageGo to next message
> Is not the shared editing for models is available in ECF?
you might wanna have a look at the Saros project [0].
Markus
[0] http://www.saros-project.org/
Re: Learning Tutorial [message #761093 is a reply to message #761051] Mon, 05 December 2011 22:03 Go to previous message
@Markus,
Sir, this Saros project is great. I could see the Source Code there. Thanks a lot.
If I have further queries, shall I contact you?
[Updated on: Mon, 05 December 2011 22:06]
Previous Topic:Remote Services Performance issue ?
Next Topic:How to start with NET4j
Current Time: Sat Apr 21 02:31:39 GMT 2018
Powered by FUDForum. Page generated in 0.02317 seconds
