Home » Modeling » EMF » CDO starting but not started - how to get more logging info
CDO starting but not started - how to get more logging info [message #759304] Mon, 28 November 2011 10:33 Go to next message
Martin Taal is currently offline Martin TaalFriend
I am trying CDO with the 4.0 latest build. I have the problem that the CDO server is starting but I can't connect. Also
the string 'CDO Server Started' is not printed in the console, giving me the idea that something goes wrong when
starting the CDO server. I can connect using telnet though and do cdo sessions repo1
See the config.xml below, the cdo server starts correctly with a previous 4.0 build.
My main question, how can I enable more logging to be printed to the console?
(I tried OMPlatform.INSTANCE.setDebugging(true), but it did not help)
Listening on port 0.0.0.0/0.0.0.0:8811 ...
CURRENT Locale: country = United Stateslanguage = English
NEW Locale: country = United Kingdomlanguage = English
!SESSION 2011-11-27 22:33:36.114 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product com.netxforge.netxstudio.server.product --launcher.XXMaxPermSize 128M
Command-line arguments: -product com.netxforge.netxstudio.server.product -data
/home/mtaal/mydata/dev/tmobile/workspaces/tm2/../runtime-netxserver_production.product -dev
file:/home/mtaal/mydata/dev/tmobile/workspaces/tm2/.metadata/.plugins/org.eclipse.pde.core/netxserver_production.product/dev.properties
-os linux -ws gtk -arch x86 -consoleLog -clean -console 8811 --launcher.XXMaxPermSize 128M
!ENTRY org.eclipse.osgi 2 0 2011-11-27 22:33:38.620
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-11-27 22:33:38.620
!MESSAGE Bundle initial@reference:file:../svn/trunk/Client/com.netxforge.netxscript.ui/ was not resolved.
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.620
!MESSAGE Missing required bundle org.eclipse.xtext.ui.codetemplates.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.editors_3.5.0.
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.621
!MESSAGE Missing required bundle org.eclipse.xtext.builder_0.0.0.
!MESSAGE Missing required bundle org.eclipse.compare_0.0.0.
!MESSAGE Missing required bundle org.eclipse.xtext.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_3.5.0.
!ENTRY org.eclipse.osgi 2 0 2011-11-27 22:33:38.627
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause
if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-11-27 22:33:38.627
!MESSAGE Bundle com.netxforge.netxscript.ui_1.0.0.qualifier [41] was not resolved.
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.627
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.628
!MESSAGE Missing optionally required bundle org.eclipse.xtext.ui.shared_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.xtext.common.types.ui_0.0.0.
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.629
[INFO] CDO server starting
!ENTRY org.eclipse.emf.cdo.server 1 0 2011-11-27 22:33:38.634
!MESSAGE CDO server starting
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://54.fwk1913643:9/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://54.fwk1913643:10/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://26.fwk1913643:3/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: This version of SLF4J requires log4j version 1.2.12 or later. See also http://www.slf4j.org/codes.html#log4j_version
log4j:WARN No appenders could be found for logger (org.hibernate.type.BasicTypeRegistry).
log4j:WARN Please initialize the log4j system properly.
27-Nov-2011 22:33:39 org.eclipse.emf.teneo.classloader.ClassLoaderResolver setClassLoaderStrategy
INFO: Class loader strategy set to: org.eclipse.emf.teneo.classloader.ContextClassLoaderStrategy
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: CDO starting but not started - how to get more logging info [message #759315 is a reply to message #759304] Mon, 28 November 2011 11:04 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal KaracaFriend
It seems you are using xtext and an editor created by it that itself depends on the IDE.
Maybe, you should get rid of the IDE dependent bundles...
Re: CDO starting but not started - how to get more logging info [message #759325 is a reply to message #759315] Mon, 28 November 2011 11:33 Go to previous messageGo to next message
Thanks, I get the same messages in a previous version of cdo, and then it started fine. In any case, my original
question (how to get more logging info), stays the same...
gr. Martin
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759330 is a reply to message #759325] Mon, 28 November 2011 12:03 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 28.11.2011 12:33, schrieb Martin Taal:
In an Eclipse Application launch you can use the Tracing tab. In standalone
http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_enable_tracing.3F should help ;-)
Cheers
/Eike
http://www.esc-net.de
Re: CDO starting but not started - how to get more logging info [message #759343 is a reply to message #759330] Mon, 28 November 2011 12:32 Go to previous messageGo to next message
Thanks Eike for your response. There is more logging/tracing now, but I don't see anything special. If you have a few
mins, can you take a look (see attached log)?
When I try to run a client side test, it timesout on the connection.The cpu is not showing any action, so it seems to be
a connection problem.
gr. Martin
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
The Netherlands
  • Attachment: cdo_start.log
    (Size: 763.20KB, Downloaded 140 times)
Re: CDO starting but not started - how to get more logging info [message #759357 is a reply to message #759343] Mon, 28 November 2011 13:31 Go to previous messageGo to next message
Am 28.11.2011 13:32, schrieb Martin Taal:
That's ~1MB of traces!
> be a connection problem.
I'm about to leave for a demo camp and tomorrow I'm on a conference in Frankfurt. Please try to skype me on Wednesday
and make sure you've TeamViewer installed ;-)
Cheers
/Eike
> gr. Martin
>> Cheers
>> /Eike
Re: CDO starting but not started - how to get more logging info [message #759365 is a reply to message #759357] Mon, 28 November 2011 13:38 Go to previous messageGo to next message
He he, it is large indeed :-), sorry, I thought your page down/scroll button would go fast!
Have a good travel, Eike!
gr. Martin
> Cheers
> /Eike
>> gr. Martin
>>> Cheers
>>> /Eike
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759367 is a reply to message #759357] Mon, 28 November 2011 13:43 Go to previous messageGo to next message
Okay the log contained all kind of unimportant things, here is one that is 100kb.
gr. Martin
> Cheers
> /Eike
>> gr. Martin
>>> Cheers
>>> /Eike
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759395 is a reply to message #759367] Mon, 28 November 2011 14:41 Go to previous messageGo to next message
Some more info, I have an IElementProcessor which opens a session a jvm connector. This is done when the activated
lifecycle event has been fired. But the jvmconnection is not possible, so the system/startup stops there (waiting for
connection) and the tcp stuff is not created/initialized in cdo. Is the ElementProcessor to early in trying to connect
to the CDO Server (even with a jvm connection)?
I added an elementprocessor to initialize some things in the database when starting the cdo server.
>>> session configuration:
final IManagedContainer container = IPluginContainer.INSTANCE;
acceptor = JVMUtil.getAcceptor(container, "default");
connector = JVMUtil.getConnector(container, "default");
// Create configuration
final CDOSessionConfiguration sessionConfiguration = CDONet4jUtil
.createSessionConfiguration();
sessionConfiguration.setConnector(connector);
sessionConfiguration.setRepositoryName(REPO_NAME);
>>> element processor:
public static class ServerElementProcessor implements IElementProcessor {
public Object process(IManagedContainer container, String productGroup,
String factoryType, String description, Object element) {
if (element instanceof IRepository) {
// create all the resources at startup
final IRepository repository = (IRepository) element;
repository.addListener(new LifecycleEventAdapter() {
public void notifyLifecycleEvent(ILifecycleEvent event) {
if (event.getKind() == Kind.ACTIVATED) {
getInstance().initializeServer(repository);
return element;
> gr. Martin
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Cheers
>>>> /Eike
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759551 is a reply to message #759395] Tue, 29 November 2011 07:06 Go to previous message
Am 28.11.2011 15:41, schrieb Martin Taal:
Tomorrow I'll try your code. More feedback then...
Cheers
/Eike
> >>> element processor:
> @Override
> return element;
>> gr. Martin
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> Cheers
>>>>> /Eike
Previous Topic:add wizard on my emf project
Next Topic:Teneo Problems using merge HbMapperException
Current Time: Sun May 27 08:15:30 GMT 2018
Powered by FUDForum. Page generated in 0.02323 seconds
