Home » Language IDEs » Java Development Tools (JDT) » Unable to update Eclipse
Unable to update Eclipse [message #758555] Wed, 23 November 2011 16:22 Go to next message
Postholes  is currently offline Postholes Friend
After this seventh fresh install, switching between Indigo 3.7 and helios 3.6. I have yet to get eclipse to connect to update itself, nor install from the google web toolkit local files. When I try the local eclipse goes online and cannot connect to whatever servers it thinks it needs.
I've been trying to run it as administrator, I shut off the local windows firewall to no avail.
I can paste the links into my web browser and download the files. Every topic I have been able to dig up on the net/forums have many of the same issues that I am running in and nobody has offered a suggestion that works, if any at all.
I am using windows 7 ultimate 64bit, Eclipse Indigo 3.7, and Eclipse Helios 3.6.
I had the Java SDK 7, and just this most recent I tried installing the JDK 6.
I also tried installing onto my windows vista 32bit system with the same problems.
When clicking on update, or install new software using the google install path, or the local install files for this it takes roughly 10-20 minutes before I get any notification at all, and all I get is failure to connect when I am clearly able to connect to the location where the files are hosted.
(I had to put spaces into the address so that I could post to the forums)
eclipse.buildId=M20110210-1200
java.version=1.7.0_01
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
Error
Wed Nov 23 07:47:02 PST 2011
Unable to read repository at http: //download.eclipse.org/eclipse /updates/3.6/R-3.6.2-201102101200 /content.jar.
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at org.apache.commons.httpclient.ContentLengthInputStream.read(ContentLengthInputStream.java:170)
at java.io.FilterInputStream.read(Unknown Source)
at org.apache.commons.httpclient.AutoCloseInputStream.read(AutoCloseInputStream.java:108)
at org.apache.commons.httpclient.AutoCloseInputStream.read(AutoCloseInputStream.java:127)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer$1.performFileTransfer(AbstractRetrieveFileTransfer.java:172)
at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:74)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
[Updated on: Wed, 23 November 2011 16:23]
Report message to a moderator
Re: Unable to update Eclipse [message #759459 is a reply to message #758555] Mon, 28 November 2011 18:23 Go to previous messageGo to next message
Was my description not specific enough? I know I was a bit.. perturbed when I put that together. Please I am still suffering from this issue and could really use some pointers/help to get this thing going. I have a few projects I need to get done very soon.
Postholes
Re: Unable to update Eclipse [message #759543 is a reply to message #758555] Tue, 29 November 2011 06:00 Go to previous messageGo to next message
Deepak Azad is currently offline Deepak AzadFriend
> Helios 3.6.
> JDK 6.
I recall seeing some issues with updating Eclipse while running on JDK
7. Did the update also not work with JDK 6.
Deepak Azad
http://wiki.eclipse.org/JDT/FAQ
Re: Unable to update Eclipse [message #759792 is a reply to message #759543] Wed, 30 November 2011 05:15 Go to previous messageGo to next message
Zeeshan M is currently offline Zeeshan MFriend
I have got the same problem;
a new machine with Win 7 Home Premium+SP1 64 Bit
JDK 1.7.0 64 Bit
Eclipse Indigo 64 Bit
Whenever I try to install anything I get "Read timed out" error, e.g.
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Unable to read repository at http : // subclipse.tigris.org/update_1.8.x/plugins/com.collabnet.subversion.merge_3.0.4.jar.
Read timed out
Unable to read repository at http : // subclipse.tigris.org/update_1.8.x/plugins/org.tigris.subversion.clientadapter_1.8.0.jar.
Connection reset
Unable to read repository at http : // subclipse.tigris.org/update_1.8.x/plugins/org.tigris.subversion.clientadapter.javahl_1.7.1.1.jar.
Read timed out
Unable to read repository at http : // subclipse.tigris.org/update_1.8.x/plugins/org.tigris.subversion.clientadapter.javahl.win64_1.7.1.1.jar.
Connection reset
Unable to read repository at http : // subclipse.tigris.org/update_1.8.x/plugins/org.tigris.subversion.subclipse.doc_1.3.0.jar.
Read timed out
Unable to read repository at http : // subclipse.tigris.org/update_1.8.x/plugins/org.tigris.subversion.subclipse.ui_1.8.3.jar.
Read timed out
(I had to add spaces in the link so I can post)
Has anyone found any solution to this ?
Re: Unable to update Eclipse [message #759815 is a reply to message #759792] Wed, 30 November 2011 07:58 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
> a new machine with Win 7 Home Premium+SP1 64 Bit JDK 1.7.0 64 Bit
> action=).
> Read timed out
> Connection reset
> Read timed out
> Connection reset
> Read timed out
> Read timed out
Try to update with a 1.6 JRE.
Dani
Re: Unable to update Eclipse [message #760036 is a reply to message #759815] Thu, 01 December 2011 03:42 Go to previous message
Thanks Dani, my issue is resolved.
Previous Topic:@RunWith(Enclosed.class) annotated JUnit test classes hang when whole project is tested
Next Topic:Already changed project name but Server view still shows old name
Current Time: Thu Feb 22 23:26:27 GMT 2018
Powered by FUDForum. Page generated in 0.02250 seconds
