Home » Eclipse Projects » EGit / JGit » Git Plugin in RCP - Wizard Error
Git Plugin in RCP - Wizard Error [message #758292] Tue, 22 November 2011 15:15 Go to next message
Marcel Austenfeld is currently offline Marcel AustenfeldFriend
I would like to use the EGit plugin in my RCP application. Everything works fine so far.
Only one error remains. If i open the Wizard "Git Repository" from File->New->Git an error is thrown:
"the selected wizard could not be started.
Plug-in "org.eclipse.egit.ui" was unable to instantiate class "org.eclipse.egit.ui.internal.repository.NewRepositoryWizard".
Does anyone know why this error is thrown?
Any help is appreciated!
Re: Git Plugin in RCP - Wizard Error [message #758330 is a reply to message #758292] Tue, 22 November 2011 18:48 Go to previous messageGo to next message
Kevin Sawicki is currently offline Kevin SawickiFriend
Member
I believe this has been fixed in master and currently in the 1.2.0 nightlies.
http://egit.eclipse.org/r/#change,4266
Re: Git Plugin in RCP - Wizard Error [message #758422 is a reply to message #758330] Wed, 23 November 2011 09:03 Go to previous messageGo to next message
O.K. Thanks for the fast reply and the information!
Re: Git Plugin in RCP - Wizard Error [message #759785 is a reply to message #758292] Wed, 30 November 2011 04:26 Go to previous messageGo to next message
eddie is currently offline eddieFriend
I know this is a bit of a NOOB question but how does one get ahold of the fix?
Re: Git Plugin in RCP - Wizard Error [message #759889 is a reply to message #758330] Wed, 30 November 2011 13:41 Go to previous messageGo to next message
Nevermind... as with all NOOB questions the answer is use a search engine Smile
Re: Git Plugin in RCP - Wizard Error [message #759998 is a reply to message #759889] Wed, 30 November 2011 20:44 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
If you want the binaries install from http://download.eclipse.org/egit/updates-nightly
If you want sources checkout the EGit contributor guide http://wiki.eclipse.org/EGit/Contributor_Guide
Previous Topic:[jgit] Find Commits for Notes
Next Topic:branch deletion disabled?
Current Time: Sun Jun 24 09:37:46 GMT 2018
Powered by FUDForum. Page generated in 0.02177 seconds
