Home » Eclipse Projects » EclipseLink » Mapping Compound PK with FK Reference?(How does one map an entity with a compound primary key that has a foreign key in it in EclipseLink?)
Mapping Compound PK with FK Reference? [message #757174] Wed, 16 November 2011 23:13 Go to next message
Shelli Orton is currently offline Shelli OrtonFriend
I've been trying to figure out how to map a compound primary key part of which is a foreign key to a parent table. This is what the tables look like:
Parent           Child
name(PK)         name(PK)
string1          parent_name(PK, FK)
                 string1
My Parent class looks like this:
@Entity
@Table(name = "PARENT")
public class Parent
    private String name;
    private Set<Child> children;
    private String string1;
    public Parent()
        // empty constructor
    @Id
    @Column(name = "NAME")
    public String getName()
        return name;
    public void setName(String name)
        this.name= name;
    // bi-directional many-to-one association to Child
    @OneToMany(mappedBy = "parent")
    public Set<Child> getChildren()
        return children;
    public void setChildren(Set<Child> children)
        this.children= children;
    @Column(name = "STRING1")
    public String getString1()
        return string1;
    public void setString1(String string1)
        this.string1 = string1;
What I'm having problems with is the Child and ChildPK classes. If all the fields of the child primary key weren't part of a foreign key, I would set them up like this:
@Entity
public class Child
    private ChildPK childId;
    public Child()
    @EmbeddedId
    public ChildPK getChildId()
        return childId;
    public void setChildId(ChildPK childId)
        this.childId= childId;
        return string1;
@Embeddable
public class ChildPK implements Serializable
    private static final long serialVersionUID = 1L;
    private String parentName;
    public ChildPK()
        //empty
        return name;
        this.name= name;
    @Column(name = "PARENT_NAME")
    public String getParentName()
        return parentName;
    public void setParentName(String parentName)
        this.parentName= parentName;
But this set up doesn't allow for the Child to reference it's Parent object.
I tried setting it up IAW the example in the "Pro EJB 3 Java Persistence API" book by Keith and Schincariol in which the ChildPK class is not Embeddable and the fields aren't annotated with Column. The Child class would be set up like this:
@Entity
@IdClass(ChildPK.class)
public class Child
    private Parent parent;
    public Child()
    @Id
        return name;
        this.name= name;
    @Id
        return parentName;
    @ManyToOne
    @JoinColumn(name = "PARENT_NAME")
    public Parent getParent()
        return parent;
    public void setParent(Parent parent)
        this.parent= parent;
        return string1;
The book notes that not all JPA implentations may support this and this seems to be the case with EclipseLink as it won't deploy in Glassfish (v3.1.1) with this error:
Error occurred during deployment: Exception while preparing the app : Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.EntityManagerSetupException Exception Description: Predeployment of PersistenceUnit [myUnit] failed. Internal Exception: Exception [EclipseLink-7233] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.ValidationException Exception Description: Mapping metadata cannot be applied to properties/methods that take arguments. The attribute [method setParentName] from class [class my.company.Child] is in violation of this restriction. Ensure the method has no arguments if it is mapped with annotations or in an XML mapping file.. Please see server.log for more details.
Re: Mapping Compound PK with FK Reference? [message #757354 is a reply to message #757174] Thu, 17 November 2011 21:30 Go to previous message
Through much trial and error, here is the correct setup:
@Entity
public class Child
    public Child()
    @EmbeddedId
        return childId;
        return string1;
    // bi-directional many-to-one association to Parent
    @ManyToOne
    @JoinColumn(name = "PARENT_NAME", updatable=false, insertable=false)
        return this.parent;
        this.parent = parent;
@Embeddable
    public ChildPK()
        //empty
        return name;
        this.name= name;
        return parentName;
Previous Topic:JPA query - NOT MEMBER OF exception
Next Topic:Re: Mapping Compound PK with FK Reference?
Current Time: Fri May 25 22:57:33 GMT 2018
Powered by FUDForum. Page generated in 0.02026 seconds
