Home » Eclipse Projects » EclipseLink » PerformanceMonitor in Standalone or OSGI environment?
PerformanceMonitor in Standalone or OSGI environment? [message #757168] Wed, 16 November 2011 21:39 Go to next message
Dave M is currently offline Dave MFriend
Is it possible to use ProfilerType.PerformanceMonitor for an EclipseLink JPA 2.3.1 application running in a J2SE or OSGI (i.e., non JEE) environment?
I configured the PerformanceMonitor via the eclipselink.profiler property in the persistence.xml but I am not seeing any output being generated. The profiled program does run longer than default statistics dump interval of one minute.
Re: PerformanceMonitor in Standalone or OSGI environment? [message #757807 is a reply to message #757168] Mon, 21 November 2011 18:40 Go to previous message
James Sutherland is currently offline James SutherlandFriend
Do you get other session logging? Have you redirected your session log or System.out.
Can you try a normal JSE environment without OSGi?
James : Wiki : Book : Blog : Twitter
Previous Topic:How can I check PersistenceContexts for equality
Next Topic:Mapping Compound PK with FK Reference?
Current Time: Sat Mar 17 04:36:25 GMT 2018
Powered by FUDForum. Page generated in 0.02092 seconds
